96-04 4wd LT
Discussion in 'Long Travel Suspension' started by dirt designs, Feb 8, 2013.
  1. Feb 8, 2013 at 7:00 PM
    dirt designs
    dirt designs [OP] Well-Known Member
    slo
    01 Tacoma race truck
    Only factory parts left is cab and frame rails
    Started the tear down and design for a 96-04 kit. No real pics but it should be pretty nice and maybe have some replacement parts for the tc/camburg kits. Its hush hush till next week
  2. Feb 8, 2013 at 10:41 PM
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    Based of all your previous work its gonna be badass forsure.
  3. Feb 8, 2013 at 10:42 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    sub'd fo sho
  4. Feb 12, 2013 at 8:41 AM
    dirt designs
    slo
    I did a quick cycle on the kit yesterday and it does pull 14" clean with only 1/4" of cv plunge, no bumpsteer, and off the shelf napa tundra cvs. With a diff spacer 15" is very possible but cv plunge will be around 5/8-3/4". Stock cv allows 1 1/2" of plunge.
    More teaser pics. I just welded up the uppers yesterday and im hoping to have at least one lower welded today...and then the cat will be out of the bag
  5. Feb 12, 2013 at 9:10 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    x2
  6. Feb 12, 2013 at 9:13 AM
    theduck911
    theduck911 Max's Canadian Twin
    Max
    Northwestern Ontario, Canada
    Locked and Geared!
  7. Feb 12, 2013 at 9:17 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    I like where this is going!
  8. Feb 12, 2013 at 11:59 PM
    dirt designs
    slo
    And a little more looky looky. This is all bolt on with a stock spindle and i can start taking orders on these guys. Making an extremely strong replacement spindle for these should be an easy upgrade with this setup. Double shear lower uniball!!
  9. Feb 13, 2013 at 12:00 AM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
  10. Feb 13, 2013 at 12:03 AM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Damn Steve! horizontal uppers and verical lowers? Seams ass backwards but I'm sure it's to cut scrub or some genius idea lol
  11. Feb 13, 2013 at 12:03 AM
    Anthony250
    Anthony
    Rialto CA
    Hows the outer end on the lower going to connect to the stock spindle?
  12. Feb 13, 2013 at 12:13 AM
    dirt designs
    slo
    Hahaha its actually the best loading for the unis. I like using the vertical lower and upper unis most of the time because it keeps the dirt out of the liners and keeps the unis alive longer. Most of the force on the lower uniball is actually vertical force from the springs/shocks pushing down and when you bottom out. A lot of the backwards force hitting the tire gets transferred into vertical force. And a taller tire means more of that force gets put into vertical force which is why "bigger tire = smaller holes"
    Antoher good thing with the vertical lower is now it has a steering stop that wont grind the shit out of the lower arms. All the bj lower arms ive seen are pretty gashed in if they pull more then 11" of travel.
    Thats the magic
  13. Feb 13, 2013 at 12:48 AM
    Spagget13
    Spagget13 Well-Known Member
    Drew
    Lake Havasu City
    01 TRD off road ext cab
    Mcm Fabrication4x4 long travel kit, ADS coilovers, ADS bumps Deaver h70/e30 Leafs, 2.5x16 king double bypasses, straight pipe after cat, Glassworks Fiberglass front and rear.
    subbed.
  14. Feb 13, 2013 at 8:05 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    :popcorn: for sure.
    Can't wait to see how this comes out.
  15. Feb 13, 2013 at 8:32 PM
    theduck911
    Max
    Locked and Geared!
    Do it :cool:
  16. Feb 13, 2013 at 8:53 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I have several possibilities I'm considering at this point in time....all of which require significant rework.
  17. Feb 13, 2013 at 8:59 PM
    kbauman92
    kbauman92 Well-Known Member
    Kyle
    North Bend
    98 tacoma ext cab
    King 2.5x6 RR coilovers eibach coils Light Racing UCA Spidertrax spacers Fiberwerx fenders
    Looks awesome! :popcorn:
  18. Feb 13, 2013 at 9:09 PM
    dirt designs
    slo
    Only one more day to go and i should have pics of the suspension together on the truck. Had to take half a day to build some parts for other customers ive been holding off, but i did get the other lower welded today. AND i just had a great idea for the engine crossover for these trucks. We'll see if it works out.
  19. Feb 14, 2013 at 6:24 PM
    dirt designs
    slo
    FINALLY some cycling pics!! (jeez about time) And looky looky NO bumpsteer! These arms have over an inch more ground clearance then the other kits on the market right now. The camburg kit in the shop hangs down almost 1.5" lower with the EXACT same tire!
    No bumpsteer is due to the new heim steering setup with double shear tabs in the correct location. Cmon, how awesome is that?
    Dalandser likes this.
  20. Feb 14, 2013 at 6:27 PM
    kbauman92
    Kyle
    North Bend
    98 tacoma ext cab
    :bowdown: so much want, i wish i had more monies
