96-04 arb-winch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by skidrow, Jul 20, 2016.
  1. Jul 20, 2016 at 12:31 PM
    skidrow
    skidrow [OP] Well-Known Member
    robert
    2002 double cab 4x4
    Bilstine adjustable 3" front--add leaf rear--skid row plates +
    Hey guys well i saved and saved and finally got that ARB bumper now I saved and saved and bought the winch I purchased the Smittybilt 9.5 k model and am wondering if there is any troubles turning the clutch lever to angle it down to fit into the arb bumper?? As i am going to be trying to do this all on my own.....i have no help near by....1469042760809-459029519.jpg
  2. Jul 20, 2016 at 12:46 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have no experience with clocking the engagement handle on this winch but I know it can be done.
    I think I read that @Delta00 did it just recently. Troy, is this the winch you have?
  3. Jul 20, 2016 at 12:47 PM
    skidrow
    robert
    2002 double cab 4x4
    Thanks man yeah i was looking all over but couldnt find anything on the combo... looks like most use the warren
  4. Jul 20, 2016 at 1:06 PM
    Mikeybuck
    Mikeybuck Well-Known Member
    SW WA
    2018, 2010, Tacoma
    If your near me, swing by and I'll give you a extra hand.
  5. Jul 20, 2016 at 1:38 PM
    Junetaco03
    Junetaco03 Well-Known Member
    Bay Area, California
    2019 TRD OFF ROAD 4x4 DCSB
    Let me know how the install comes out I'm about to add a winch, smittybilt xrc8 on the same exact bumper next week. Wondering because on the second gens you need longer cables. "From what I hered"
  6. Jul 20, 2016 at 2:07 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    2002 Toyota Tacoma 4WD
    Check Build
    I have the 2nd gen Smitty x20, super easy to clock it.
    Digiratus[QUOTED] likes this.
  7. Jul 20, 2016 at 3:20 PM
    skidrow
    robert
    2002 double cab 4x4
    Ok ill take pics and post an update this weekend.i just hope it all goes smooth!!! And i hope i can lift it back on by my self....
  8. Jul 20, 2016 at 3:27 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Oh man, my bumper with a winch was really heavy. Had to use one of those engine hoists to get it up there.
    skidrow[QUOTED][OP] likes this.
  9. Jul 20, 2016 at 3:29 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    X2, I had to use a motorcycle jack to get mine on, would have been really sketchy otherwise
    skidrow[OP] and Delta00[QUOTED] like this.
  10. Jul 20, 2016 at 3:33 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Forklift... :oops:
  11. Jul 20, 2016 at 4:27 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    You mount your solenoid in the bumper?
    skidrow[OP] likes this.
  12. Jul 20, 2016 at 4:29 PM
    skidrow
    robert
    2002 double cab 4x4
    Ok ive seen alot of guys put it on the top in between the fog lights is that a bad idea?
  13. Jul 20, 2016 at 6:10 PM
    Delta00
    Delta00 ᕕ( ᐛ )ᕗ
    Troy
    Chandler AZ
    Check Build
    Not sure, its exposed to the elements more. I made room for the solenoid inside my bumper.
  14. Jul 20, 2016 at 6:11 PM
    Speedytech7
    Depends on how well weather proofed it is and whether or not it is using contactors or solenoids.
    skidrow[QUOTED][OP] and Delta00 like this.
  15. Jul 20, 2016 at 8:40 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes sir
    This VVVV
    The contracor inside the black box is vulnerable to corrosion. The high amperage that goes thru it mixed with moisture (mud, snow, rain, etc.) can create issues. If you mount it exposed, make sure it is well sealed.
    Putting it out of direct impact from the elements seems like a better option to me. I still sealed it with silicone because even in the bumper or under the hood, it is going to get exposed.
  16. Jul 22, 2016 at 11:20 AM
    Junetaco03
    Just installed the winch yesterday on the same bumper. I didn't have to take the bumper all the way out. Just removed the top bolts and pulled the bumper out just a enough to place the winch on it.
    *extra hands to help will be key. Good luck
  17. Jul 22, 2016 at 6:18 PM
    skidrow
    robert
    2002 double cab 4x4
    Thanks for all the tips guys!!! I really appreciate it !! Ill be starting on it sat afternoon also just got the fog lights to put on i hope they fit they
  18. Jul 22, 2016 at 6:21 PM
    skidrow
    robert
    2002 double cab 4x4
  19. Jul 23, 2016 at 2:08 PM
    skidrow
    robert
    2002 double cab 4x4
    Well starting on the winch install but trying to figure out the proper way of clocking the gearbox so I can grab the clutch release cable through the bumper does anyone know can i just turn it where i want it or do i really have to clock it 36 degree increments 14693080038681135497407.jpg 14693080326341331486512.jpg
  20. Jul 23, 2016 at 2:21 PM
    skidrow
    robert
    2002 double cab 4x4
    Oh wate brain fart I figured it out
