96-04 Elite Off Road Plate bumper
Discussion in 'Elite Off-Road' started by Timicha, Jun 22, 2010.
  1. Nov 6, 2010 at 9:37 AM
    #381
    Timicha
    Timicha [OP] Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    right now people from canada are just having it shipped to the closest fastenal on by the border and coming across to get it. i'll talk to the guy at fastenal on monday to see if he figured out anything else
  2. Nov 6, 2010 at 7:21 PM
    #382
    phidauex
    phidauex Well-Known Member
    Sam
    Boulder, CO
    '96 4x4 V6, manual, 201k
    Small lift and a topper!
    Installed the bumper last night! Looks great. Still need to wire up the winch and spool the rope on, but the bumper is fully painted and attached. I did modify it to add a 2" receiver - breaks the clean lines a bit, but I move enough trailers around to warrant a front receiver point. I used a 12" receiver tube, with about 2.5" cut off. It is welded front and back, and rosette welded through two holes cut in the bottom of the winch mounting plate.
    Here are the bumper mount points - it ties in using the front threaded hole, two directly below it (not visible here), and the two on the outboard side of the frame, for 10 total mounting points! I added another weld bead to reinforce the threaded insert in the frame. People who do heavy winching should cut that insert out, and add a new one made out of much heavier material (1/4" angle iron slid into the frame and rosette welded is popular).
    Test fitting the bumper - currently attached with only the main front mounts. I lined up the other mounts (left unwelded on mine by request), bolted them in place, then tack welded while the bumper was on the truck. Perfect alignment. ;) The jack is slightly tweaking the alignment while I tighten everything up. It is really hard to get a socket into those holes for the main mount positions! I did install the bumper myself, with the help of the jack and some quick bolting, but two people would certainly make it easier.
    As you can see, the fit is perfect! Of course, my truck has taken a few hits before, so IT isn't perfectly straight. ;)
    The backside of the bumper, with mounts welded in place.
    The final fit, with winch mounted, and fairlead attached. Looks great! I painted with Rustoleum Hammered, which I'm about 70% satisfied with. The black isn't as black as I hoped it would be. Also, when brushed on it is very hard to maintain an even thickness. ALSO, it is darker colored out of the spray can than out of the quart can. Sigh. I'm really just being picky, it looks good, and is durable. I'll repaint after I bash it up a bunch. ;)
    Side view of the finished bumper. The light hoop is in exactly the right place - it sticks out about .5" farther than anything else, and you can just see it sticking out over the hood while driving - any higher an it would be annoying, but as it is, it makes it easy to park without bashing stuff with the new, longer front of the truck.
    -Sam
  3. Nov 6, 2010 at 7:37 PM
    #383
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Nice job Sam. Your a better man than me. Took two of us with the winch in there and another set of hands would've made it even better.
    Looks really, really good! Nice write up too. Tim does does GREAT work doesn't he!
  4. Nov 6, 2010 at 8:05 PM
    #384
    Pingo
    Pingo Well-Known Member
    North Pole, AK
    2014 S/C TRD Offroad A/C
    God I want one so bad... Do you have any pics of the full grille guard version? Also would shipping to alaska be ridiculous? =/
  5. Nov 6, 2010 at 8:14 PM
    #385
    Timicha
    TIM
    04 White Tacoma
    probably be 150 and i'm working on the 1st full grill guard right now on stillar's bumper
  6. Nov 6, 2010 at 8:18 PM
    #386
    Timicha
    TIM
    04 White Tacoma
    damn good job man! and i cant thank you enough for that write up, i never expected that from anyone but ya thanks a lot! and it looks awesome!
    Thanks! i does does a lot of work haha :D
  7. Nov 6, 2010 at 8:22 PM
    #387
    Pingo
    North Pole, AK
    Alright cool lookin forward to it... Wish I was still in washington :(
  8. Nov 6, 2010 at 8:27 PM
    #388
    Timicha
    TIM
    04 White Tacoma
    it'll be completely finished tomorrow so check back tomorrow night for photos
  9. Nov 6, 2010 at 9:21 PM
    #389
    Digiratus
    Roaming the PNW
    The RedHead
    Fixed it! :brianr:
    x
    x
    x
    x
    x
    x
    x
    x
    x
    x
    x
    x
    x
    x
    x
    x
    x
    x
    x
    :D
  10. Nov 6, 2010 at 9:38 PM
    #390
    Timicha
    TIM
    04 White Tacoma
    oh haha i does does GREAT work lol :D
  11. Nov 6, 2010 at 9:54 PM
    #391
    Digiratus
    Roaming the PNW
    The RedHead
    :rant: most of the time :annoyed:
    :pout:
  12. Nov 6, 2010 at 10:05 PM
    #392
    Timicha
    TIM
    04 White Tacoma
    :anonymous: lol
  13. Nov 6, 2010 at 10:14 PM
    #393
    Digiratus
    Roaming the PNW
    The RedHead
    :eek:
  14. Nov 7, 2010 at 6:08 PM
    #394
    Timicha
    TIM
    04 White Tacoma
    Got the first full grille guard done today turned out pretty sweet if you ask me. here it is when i tacked it together on the truck last night.
  15. Nov 10, 2010 at 1:15 PM
    #395
    evanch123
    evanch123 Active Member
    denver
    1998 Tacoma Extra Cab
    K&N FIPK Jardine Cat Back
    Are you still building these? How long does it take to build? Are you backed up?
    Thanks!!!
  16. Nov 10, 2010 at 1:16 PM
    #396
    Timicha
    TIM
    04 White Tacoma
    yep still building and if you ordered now you would probably get it within a month
  17. Nov 10, 2010 at 1:20 PM
    #397
    Pingo
    North Pole, AK
    Well you still be taking orders around christmas/new years time? I probably won't have the money to order till then.
  18. Nov 10, 2010 at 1:51 PM
    #398
    Timicha
    TIM
    04 White Tacoma
    yep i'll still be doing it. send me a PM and i'll send you my contact information and you can call me when your ready
  19. Nov 11, 2010 at 1:30 PM
    #399
    sledder
    sledder Member
    Will
    Little-fun
    99 TRD 3.4V6 manual
    IVD front coilovers, SPC/Light Racing UCAs, Alcan 8 leaf springs, OME Nitrochargers, Timbren bump stops, sliders, clear lenses (all corners), and cheap-ass spray in bedliner from previous owner. stereo and alarm.
  20. Nov 11, 2010 at 6:12 PM
    #400
    Timicha
    TIM
    04 White Tacoma
    gonna post some more pictures of the full wrap grille guard in a second!
