96-04 Lower ball joint failure ?SOLUTION?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JTtheMechanizer, Dec 28, 2015.
  1. Dec 28, 2015 at 1:50 PM
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    Only way to go is OEM for the lower ball joints . Someone on the site here had cut a few different ball joints to compare the construction and design. Just to add my .2cents , I've seen a few 1st gen tacomas and some later gen 4runners running around at 200k+ plus with original ball joints.Not a good idea but people do it. Heck mine are still good at 180xxx miles, boot is leaking that is about it, guess I am driving on borrowed time.
  2. Dec 28, 2015 at 3:49 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Always go with OEM when it comes to critical parts like this, you won't be sorry. Might cost a bit more than aftermarket but I assume you'd rather spend that than risk an accident. The ball joint design on these trucks is their only real weak link that needs to be monitored closely like the frames.
    Brie likes this.
  3. Dec 28, 2015 at 4:37 PM
    98tacoma3rz
    98tacoma3rz Well-Known Member
    lancaster, pa
    2002 Double Cab Trd
    Actually, 555 is pretty good. The real sankei 555 thats Made in japan.(not rebranded Autozone junk) Sankei 555 makes a lot of oem parts for Japanese auto manufacturers. I would trust them over moog. But back to the lower ball joint issue. I had over 200k miles on my original oem ball joints. Wheeled the hell out of it too. Replaced them with oem again. Actually they were still good but just wanted to be safe. I highly recommend oem for suspension parts.
  4. Dec 28, 2015 at 4:37 PM
    98tacoma3rz
    lancaster, pa
    2002 Double Cab Trd
    Yep I agree! Don't skimp on suspension parts.
  5. Dec 28, 2015 at 6:16 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Brie likes this.
  6. Dec 28, 2015 at 7:04 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    in my opinion, NAPA is king with their NAPA Chassis line of steering and suspension products. i honestly believe these parts are better than OE quality. check out this video. it details the design differences.
    here's another video by raybestos with more detail.
  7. Dec 29, 2015 at 7:42 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    You could always SAS if you REALLY wanna fix the LBJ problem... :notsure:
    Rmodel65, Ugly Betty and NateMob like this.
  8. Dec 29, 2015 at 8:29 AM
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    I was gonna say SAS as well...
  9. Dec 29, 2015 at 9:43 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    All those videos mask the important fact that they do not apply across the board to all applications. The Moog, Rabestos and bla bla bla "premium" ball joints for 1st gen 6 lug Taco are all re-branded aftermarket Sankei/555 joints, period. There are only 3 types/grades/manufacturers of 1st gen 6 lug Taco LBJ's on the market, OEM/555, aftermarket 555 and Chinese super cheapo knock offs.
    As far as a "solution" to a catastrophic failure other than the relatively brief number of defective factory joints, it's called maintenance. They do not "just come apart" until they are well past worn out.
    When a tire is worn out you replace it or risk a potentially catastrophic failure, LBJ's are no different.
  10. Dec 29, 2015 at 10:52 AM
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    The bj isnt really the issue on these trucks its the bracket between the bj and control.arm that fails. Bjs go bad, thats part of maintaince. These brackets however have a tendancy to snap in half. I broke 3 including one at 70mph before I went LT (went lt because that was the easy fix). And i was not beating on truck at all either.
    Check out he 5 lug section, lot of info about people looking for custom cnc'd brackets and such to fix issue. As fsr as Ive seen nobody has ever pulled trigger though.
  11. Dec 29, 2015 at 11:00 AM
    Siebler
    CJ
    Portland, OR
  12. Dec 29, 2015 at 11:09 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I have 2.5" lift (toytec coilovers) I replaced the lowers with Napa Chassis greasable lower ball joints. After 10K they still function and look brand new. They are not OEM but they work well IMO. It's on my 98 4x4. 32x11.50 tires and I am by no means easy on my pickup.
  13. Dec 29, 2015 at 7:17 PM
    CodeSeven
    Serge.
    Coachella Valley
    if you truly believe this, buy 1, cut it open, prove them wrong, and start a class action suit over false advertisement. the information in those videos are not false. and raybestos doesn't sell their professional line to everyone. it's almost entirely proprietary to NAPA.
    why do you think you can't find any raybestos on rock auto? or their professional line in just about any parts store other than napa?
  14. Dec 29, 2015 at 9:59 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    He did cut one open. Several in fact.
    Caligula likes this.
  15. Dec 29, 2015 at 10:16 PM
    #35
    CodeSeven
    Serge.
    Coachella Valley
    If its the one i that video where a bunch of balljoints were in the coca cola crate ive seen the beginning. And i can tell you he didn't open a raybestos/napa balljoint.
  16. Dec 29, 2015 at 10:23 PM
    #36
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Let me ask, if price and availability were all the same between the NAPA and OEM Toyota, which would you go with on your truck?
    If i was to go to NAPA and just ask for their LBJ for my Tacoma, do they carry different lines of NAPA branded parts, or would they just have a single Raybestos brand of LBJ?
  17. Dec 29, 2015 at 10:31 PM
    #37
    CodeSeven
    Serge.
    Coachella Valley
    Depends on the store. But for the most part, they all should be pushing their premium "NAPA Chassis Parts"/ Raybestos Professional chassis parts.
    They do offer a value line that i believe is supposed to be actual moog reboxed. It is not branded as napa. Plus they have a supplier called Altrom that provides many oem and oes parts from the manufacuturers. Some reboxed and debranded, some actual. Theres a good chance youll get oem replacement parts from that supplier.
    And yes, when my chassis parts go bad, i will be replacing them with napa chassis products.
  18. Dec 29, 2015 at 10:36 PM
    #38
    CodeSeven
    Serge.
    Coachella Valley
    Actually all my ball joint boots and sway bar link boots have cracked open, im just keeping a penny pincher mentality as im trying to save up for a house
    Brie likes this.
  19. Dec 29, 2015 at 10:38 PM
    #39
    Caligula
    Los Angeles, CA
    Even if price wasn't an issue, still over OEM Toyota? That says a lot. So quality wise, Raybestos for Toyotas would be to Lemforder for Mercedes/BMW.
  20. Dec 29, 2015 at 10:45 PM
    #40
    Holy schmidt
    Holy schmidt Well-Known Member
    Wyatt
    Nebraska
    So you know your truck needs parts to keep it safe from potential failures but don't fix it?
    I got 200k out of my first set before I decided to replace them and went with oem. I had no issues with mine but they were ready to be replaced which "solved" them I guess
