96-04 Lower ball joint failure ?SOLUTION?
Discussion in '1st Gen. Tacomas (1995-2004)' started by JTtheMechanizer, Dec 28, 2015.
  1. Dec 29, 2015 at 10:49 PM
    #41
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    Im at 202k, no idea if they've ever been replaced as i bought the truck at 185k 2 years ago. Probably not.
    my Taco is still getting aligned without issues, so there's no endplay. Im not showing any signs of problems, nor am i getting loose/weird steering while driving.
  2. Dec 29, 2015 at 10:52 PM
    #42
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    I went with moog for my 3rd gen 4Runner (same design as 1st gen taco) and they were absolute crap. Had them on for 1.5 years and they made the steering very difficult, especially at freeway speeds. I finally broke down and bought OEM and the difference is very noticeable. When I removed the moog they had very limited movement in the ball joint and were extremely stiff. I had kept them greased every 7-10k but still they seemed to have "locked up" over that time. I'm also in California where I don't ever deal with road salt or rust.
    My oem have been so much better and instantly I felt a better ride on the streets and freeway. No more sticky steering and my steering wheel returns back to center again. I know it's easy to say moog or others will be fine, but honestly the OEM's typically last 150-250k. Do you really think you will be reaching those type of miles in your ownership where new OEM's will have the risk of failing again?
  3. Dec 29, 2015 at 10:52 PM
    #43
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    296k on mine, original. :luvya:
    They visually need to be replaced, but ive been driving a lot between LA and Phoenix lately at 95mph. Still feels solid.
    tymeson likes this.
  4. Dec 30, 2015 at 11:01 PM
    #44
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    That would suck to lose one at those speeds! You're a daring individual my man, haha.
  5. Dec 30, 2015 at 11:35 PM
    #45
    Caligula
    Los Angeles, CA
    Don't act like you've never said "I'll be buried in my truck". :D
  6. Dec 31, 2015 at 11:06 PM
    #46
    Siebler
    Siebler Duck Killing Machine
    CJ
    Portland, OR
    99 Long Travel 5 lug, 01 Tundra 4wd
    TC LT Front, F67 on 12" shackle, LCE Underdrive Pulley, Flex-a-lite fan, DT headers, Super 44 muffler, 4:11's and Aussie Locker, 22 Gallon Fuel Cell, Beard seats, sliders, bed cage
    Having had a bj break at 70mph i sure the fuck wouldnt do it again.......
    Bent frame, ruined every piece of suspension, killed front tires. It wasnt worth 40.00 in parts you could replace in 20 minutes thats for sure.
  7. Dec 31, 2015 at 11:18 PM
    #47
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Most of us that wrench as a hobby can recognize a failing ball joint. Anyone that knows the ball joint is going out will get a new one to replace post haste. Once you've replaced your ball joints, you know what the symptoms are. The risk of an after market ball joint letting go in any driving situation is greatly reduced.
    The people that have had one separate didn't know the sounds and feeling they make.
    Everyone in this thread understands the danger and damage that can occur when a BJ separates.
    I would like to think if you are on this site, there is pretty good chance you are gonna take your vehicle maintenance seriously and get the thing changed.
    Again, once you have changed the ball joint once, you realize the job isn't that hard for a skilled do it your selfer. I see no reason not to buy the cheaper ball joints with the lifetime warranty. I like spending time working on my truck. Its relaxing and a ball joint change out is not going to ruin shop time at all.
    tymeson and SHIfTHEAD like this.
  8. Jan 1, 2016 at 10:38 AM
    #48
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Is the Low Range Off-road YouTube video a good reference for LBJ replacement? Are there specific BJ puller tools that would make it easier than just smacking the LCA with a hammer?
  9. Jan 1, 2016 at 11:17 AM
    #49
    SCRunner12
    Robert
    Santa Cruz, CA
    I used a 2 ton 3 arm puller. Worked like a charm and it popped right out. If you deal with rust I'd bump up to a larger puller but they work great.
  10. Jan 1, 2016 at 7:49 PM
    #50
    Rmodel65
    Rmodel65 Yukon Cornelius
    Jawja
    1996 Yota 4x4
    Viper Red paint
    Hammer is the easiest way...
    koditten likes this.
  11. Jan 1, 2016 at 8:40 PM
    #51
    koditten
    Kirk
    Central Michigan
    Don't even own a separator. The hammer method works great because there is much less chance at damaging the boots.
  12. Jan 1, 2016 at 8:53 PM
    #52
    SCRunner12
    Robert
    Santa Cruz, CA
    I borrowed one from a parts store, but a hammer isn't a bad option either.
  13. Jan 2, 2016 at 10:34 AM
    #53
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    the solution is easy, its a ware item, so change it when it gets loose and you wont have issues. leave it loose and you will have a failure.
  14. Jan 5, 2016 at 9:56 PM
    #54
    JTtheMechanizer
    JTtheMechanizer [OP] Member
    Justin
    29 palms
    98 Tacoma and 87 pickup
    87 pickup-37x14.50r15 toyo m/t, SAS with FJ80 high steer kit,Arb air locker on front axle full time locker for rear axle,twin stick transfer case,and more and more upgrades 98 Tacoma - 35x12.50 BFG KO2 on 15x8 American racing baja wheels,Dual spares,long travel,rear shackle lift,fiberglass front and rear fenders,caged bed,magnaflow exhaust,and my work in progress
    The part was new in may 2015,i rotated and balanced the tires,greased all zerk fittings and repacked the front bearings in early november. I checked for play in the wheels and it all felt good. It must have been a defective part. From now on i will check ball joints more often. And i plan to buy lifetime warranty ones and replace one a year or so.
  15. Jan 6, 2016 at 4:43 AM
    #55
    Ritchie
    Ritchie Well-Known Member
    San Diego (North County)
    RC Step side Pre-runner
    2.7 w/auto, 4WU 3 link, F & R Diamonds, ARB's F/R w/ Yukon 5.29's, Inchworm 4.7 Lefty, Deavers, ARB OBA, Schrockworks up front.
    When I had IFS, I took my truck to the dealer for a coolant flush. They asked me if I'd been informed of the LBJ recall. I had not.
    They flushed the system and then changed the LBJ's at no cost.
    Can't hurt to ask the dealer.
  16. Jan 6, 2016 at 5:36 AM
    #56
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Being out in that desert environment, I would definitely push grease into those ball joints at least every 3000 miles or a bit less. Some rough gritty country down that way. I put some miles down out in the Mojave around Yucca Valley and out by landers, Joshua Tree, ect. I can see where you could wizz thru a ball joint pretty quick if it was left on it's own. Not implying that you ignored it, just saying.
  17. Jan 8, 2016 at 9:47 AM
    #57
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I'm not sure that I understand. If you buy "lifetime warranty ones" then why would you replace them each year?????
  18. Jan 8, 2016 at 9:56 AM
    #58
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    The video has the wrong torque spec listed I believe. I think they were using the torque spec for the 4Runner which is slightly less than the Tacoma.
  19. Jan 8, 2016 at 10:10 AM
    #59
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    59 ft/lbs is correct i believe
  20. Jan 8, 2016 at 6:47 PM
    #60
    40950
    CR, WA
    stock
    There all free after the first one :thumbsup:.
