96-04 lower balljoints
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by OZh88, Mar 7, 2011.
  1. Mar 7, 2011 at 11:22 PM
    OZh88
    OZh88 [OP] Active Member
    brandon
    the o.c.
    96 taco wannabe TT and 08 TUNDRA CREWMAX
    hey i have a set of stock lower balljoints that i had as spares. no longer need sold the truck. came off the truck at 60k when i put LT and upgraded to moogs. $60obo for the pair.
    call or text 949 228 029eight
  2. Mar 8, 2011 at 3:43 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Please post a picture of the ball joints you are selling.
  3. Mar 8, 2011 at 8:47 PM
    OZh88
    brandon
    the o.c.
    THERE STOCK BALLJOINTS. IF YOU ARE INTERESTED IN THEM PM ME AND ILL SEND YOU PICS
  4. Mar 8, 2011 at 8:50 PM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
  5. Mar 9, 2011 at 11:04 PM
    OZh88
    brandon
    the o.c.
    bump with a pic
