96-04 Tacoma 5-lug LT
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by noSKills858, Jan 9, 2012.
  1. Jan 9, 2012 at 8:09 PM
    noSKills858
    noSKills858 [OP] battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Kit comes with:
    -UCA (modified to run 3/4" heims) & uniball
    -LCA (new bushings)
    -Balljoints (+1 spare)
    -Spindles, rotors, hubs, calipers, etc.
    -Billet steering extension w/ 3/4" heims & 5/8 bolts.
    Extra balljoints, steering knuckles, and wheel bearings included.
    $1500 obo.
  2. Jan 11, 2012 at 11:15 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    bump for legit kit!
  3. Jan 13, 2012 at 6:24 PM
    noSKills858
    Alex
    Poway, CA
    Thanks buddy, this kit works great esp. with dual rate 10" 2.5 coilovers.
  4. Jan 13, 2012 at 7:36 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    bump! truck looks sick got any better pics and what hood and front fenders are those?
  5. Jan 13, 2012 at 11:31 PM
    noSKills858
    Alex
    Poway, CA
    This is an FS thread only...
    But if you want to know, the fenders and hood are Glassworks Extreme Kit modified to 01-04.
  6. Jan 14, 2012 at 6:17 AM
    tacomaforlife
    Robbie
    AIKEN, SC
    :annoyed:sorry well make a build thread!
  7. Jan 16, 2012 at 7:09 PM
    noSKills858
    Alex
    Poway, CA
    Too late for that.
  8. Jan 24, 2012 at 5:58 PM
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    What size coilovers were you running? Travel/ width numbers? And most importantly, how was the ride on the street? Looking to ditch my current mid travel set up but I worry how it drives on the street.
  9. Jan 25, 2012 at 2:20 PM
    noSKills858
    Alex
    Poway, CA
    Kit was designed to run a 10" 2.5 C/O - But you can get away with 8" stroke Get's about 16'ish travel with the Fabtech spindles, around 13-14 with stock.
    It's 5.5 wider per side unless you run the Fabtech spindle.
    It rides very nice on the street, much better than stock. I've had this kit for about 4-5 years now and it was mainly used on my DD/weekend warrior. I was very pleased with how it works.
    Here's a side pic with the Fabtech spindles at droop:
  10. Jan 25, 2012 at 5:17 PM
    jeffz0rz
    san diego
    Well I might have to come check it out. I'm in alpine so I'm not far. Reason you are selling the kit? Ill have to track down some coilovers unless you might be selling yours too?. You think the TC plated shock mount would work with this kit?
  11. Jan 26, 2012 at 12:06 AM
    noSKills858
    Alex
    Poway, CA
    I don't have the kit on my truck right now so unless you want to check it out anyways that's fine. I'm selling it because I'm putting too much abuse on it and would rather not destroy it and let someone else have fun with it.
    As far as the coil overs go I'm hanging on to them.
    You may be able to get away with the TC buckets but the UCA's won't be mounted off the cross member since I deleted that.
    I can do the full install for a couple bucks more if you are able to leave your truck with me for a few days too.
  12. Jan 28, 2012 at 1:44 AM
    noSKills858
    Alex
    Poway, CA
    I can do this for anybody who would like to run this kit.
  13. Jan 28, 2012 at 7:25 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    Sick bro!
  14. Feb 1, 2012 at 10:42 AM
    noSKills858
    Alex
    Poway, CA
  15. Feb 2, 2012 at 4:05 PM
    TRDChris
    TRDChris Well-Known Member
    La Puente
    5 lugger
    H.I.D 6000K, 5% tint all around, black on blacked out rims(sprayed stock rims), fog light mod, deckplate mod, plastidipped bumper and interior, self made eyelids, window visors, clear corners, Billet grille, trd grill emblem
  16. Feb 5, 2012 at 5:43 PM
    noSKills858
    Alex
    Poway, CA
    Bump, need it gone.
