96 2.7 engine noise after warm
Discussion in '1st Gen. Tacomas (1995-2004)' started by tt315, Sep 20, 2015.
  1. Sep 20, 2015 at 10:46 AM
    tt315
    tt315 [OP] Member
    96 tacoma 2.7 auto
    Hello,
    First time posting. I picked up a 96 2.7 auto tacoma to replace my 92 pickup that i had for eleven years but was starting to rust a little too much.
    The replacement tacoma has 138,000 miles on it. At the time of purchase it has a cherry bomb exhaust on it but the engine sounded fine. I removed the exhaust in favor of a stock exhaust and changed to oil to mobil synthetic.
    Once I started it back up I could now hear a new noise coming from the engine. It now sounds like a diesel once warm. maybe 30 seconds to a minute after starting The noise appears to be coming from the timing chain area and goes away under acceleration. Before i rip into it (or let a shop) I was curious if anyone has an opinion on the sound.
    thanks
  2. Sep 20, 2015 at 11:12 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Welcome to the forum.
    That sounds really bad dude. Hard to tell without standing there, but its most likely a valvetrain issue, timing chain slapping, etc. Have you checked the spark plugs? It sounds like its more frequent than a loose plug, but check anyway. Guy probably put the cherry bomb exhaust on there to mask the engine noise.
  3. Sep 20, 2015 at 4:43 PM
    tt315
    tt315 [OP] Member
    96 tacoma 2.7 auto
    The spark plugs are tight. I am leaning towards timing change slapping as well. I need to pick up a manual so i can decide what to do next.
  4. Sep 20, 2015 at 6:57 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Having a similar sounding issue with my 3.4 but not at idle. Does it make the noise when under load acceleration?
  5. Sep 21, 2015 at 3:35 AM
    tt315
    tt315 [OP] Member
    96 tacoma 2.7 auto
    when under load the noise goes away. when i bought it was a quart and half low of oil
  6. Oct 8, 2016 at 6:51 PM
    Will4x4
    Will4x4 New Member
    95 Taco 4x4
    Did you ever find the solution to that noise?
  7. Oct 10, 2016 at 1:40 PM
    tt315
    tt315 [OP] Member
    96 tacoma 2.7 auto
    no. i did not. i put in new spark plugs and it went away for the most part. two weeks ago it came back and new spark plugs did not help. If you figure it out please let me know. Truck still runs great though
