96 2.7 oil leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by shawnster88, Jan 22, 2017.
  1. Jan 22, 2017 at 7:56 PM
    shawnster88
    shawnster88 [OP] Well-Known Member
    Shawn
    Defuniak Springs, FL
    96 Tacoma Reg cab 2.7 5 speed
    OME 881 coil springs, OME nitrocharger sport shocks front and rear. Nitro 4:56 gears. ARB rear locker. Shrockworks front bumper with Warn M8000S winch. 17x9 SCS Ray 10 wheels w/ 285/70/17 Toyo Open Country RT Trail tires. Corbeau Trailcat bucket seats. Go Rhino roll bar w/ KC Daymaker lights. GMRS Radio. Ham Radio.
    My 96 2.7 has an oil leak. Not sure where. The previous owner thought it was from the oil pan. I got a pan gasket but haven't changed it yet after seeing how much of a pain it is. I'm not certain it is coming from the pan. It leaks about a quart every 4-5k miles. What can I clean my engine with to help find it? I see oil on the front passenger side of engine. Is there a common place that leaks on these engines?
  2. Jan 22, 2017 at 9:41 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Any good degreaser, the cleaner you get it, the easier it will be to pinpoint. Just don't go to crazy on cleaning up top around plug wires and distributor, etc.
  3. Jan 22, 2017 at 9:45 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Possibly coming from the distributor seal, mine leaks from there quite a bit...
  4. Jan 22, 2017 at 11:08 PM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Clean the engine, wait to see where it comes from. Most likely its the oil pan.
  5. Jan 23, 2017 at 6:03 AM
    rglsr
    rglsr Well-Known Member
    California
    Start with a good degreasing and observe as it starts to leak. If it's up high might be valve cover and/or timing cover, I had a high mileage 2.4 which did that.
    Seals/gaskets don't last forever....truck still ran great though.
  6. Jan 23, 2017 at 6:13 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    My truck had 61k on it when I got it last year and the valve cover was still leaking. Apparently valve covers and rear main seals are common leaks on the 3rz
  7. Jan 23, 2017 at 6:14 AM
    98tacoma27
    Ben
    Not Beech Creek
    This is the same stuff as Gunk and cheaper. You can get it at Wal-Mart. Another way to help pinpoint is to lay a fresh piece of cardboard down under the motor after you park it for the night. That help determine you have a leak somewhere else.
  8. Jan 23, 2017 at 8:00 AM
    tony2018
    tony2018 Well-Known Member
    I agree with all about cleaning up the engine to pinpoint the leak, all common areas are oil pan, valve cover, distributor and rear main seal. If it hasn't been replaced yet it would be a good idea to schedule some downtime to do so.
  9. Jan 23, 2017 at 6:42 PM
    shawnster88
    Shawn
    Thanks guys. It's got 177k. It's not dripping on the ground. I think it's dripping or running down into the skid plate so the cardboard thing wouldn't work unless I take the skid plate off. I have a company vehicle so I only drive it on the weekends. If I drive it about an hour I can smell the burning oil when I stop. I'll get some degreaser and spray it this weekend and look for the leaks after that in the areas you guys mentioned.
  10. Jan 23, 2017 at 6:51 PM
    SOMDTACO
    SOMDTACO Well-Known Member
    Sean
    Southern Maryland
    96 Extended Cab 4x4 2.7 MT
    New Taco: 96 DLX Extended Cab 4x4 2.7,MT, Bilstein 5100s at 2.5 and HS 3 Leaf AAL Old Taco: 11 Prerunner Maxtrac Spindles in the front, 2'' AAL with Bilstein 5100 extended in the back. 18'' Milanni Stellars wrapped in 265/70/18 General Grabber tires.
    Another common leak source on the passenger side of the engine is the oil filter housing. Mine just started leaking from there. Looks like an easy fix, just gotta do it.
