'96 Honda Accord Issues
Discussion in 'Technical Chat' started by Khaos, Oct 19, 2009.
  1. Oct 19, 2009 at 2:20 PM
    Khaos
    Khaos [OP] Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Helping a friend with her '96 Accord V6... could use some advice on whats up and how to fix it...
    Firstly, The car will start only if I jump it, but will only run for about 30 seconds before shutting off. I know it has gasoline in it. Won't start without the jumper. I use a jump starter and not cables on my truck so it still is getting power from the jumper when i try to run the car... the battery is gone and I know this but the car should run after being jumped.
    Also, the transmission is going. You have to take your foot off the gas peddle to get the gears to shift when driving. Otherwise it will not shift and revs pretty damn high while driving normally.
  2. Oct 19, 2009 at 2:27 PM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    car would only keep running after being jumped if the alternator is good
  3. Oct 19, 2009 at 6:46 PM
    Khaos
    Bryant
    Bump.
  4. Oct 19, 2009 at 6:52 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Her problem is she doesn't own a tacoma ;)
    Sounds like fuel pump and alternator may be dead, with a the tranny going soon. Tranmissions are expensive, and 13 year old cars are cheap. I was in a simillar situation (bad fuel pump / tranny) and I just decided to donate the car as fixing it didn't make sence when comparred to the value of the car. Good luck.
  5. Oct 19, 2009 at 6:55 PM
    TBAGRR
    TBAGRR Well-Known Member
    Md
    07 4x4 sport
    Trd intake Doug Thorley long tubes URD short shifter Eibach front springs Tsb rear leafs
    first thing is disconnect the positive and negative cable and hook it up to the jump box to completely bypass the battery in the car, (if the battery has a bad cell sometimes it can cause the car to die) however the car dieing could also be a ignition coil, i have seen many of these gone bad in these, other than that i havent seen any trans problems in these so..... not sure there, also if the car has less than 150k miles on it honda had a recall on the ignition system and most check engine components, just thought i would throw it out there for you
  6. Oct 19, 2009 at 8:44 PM
    Khaos
    Bryant
    The car is not worth much of anything... It's got a 236K miles... We just need to get it running well enough to transport her to work when I'm in school for the time being. I'm hoping to get her into something else around the end of the year.
    How difficult/expensive is it to fix an ignition coil?
  7. Oct 19, 2009 at 9:38 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The ignition coil is easy. FIRST, you should replace the battery, and throw a multi meter on the Alt.
  8. Oct 20, 2009 at 11:25 AM
    Khaos
    Bryant
    Went to jump it again today, absolutely nothing happens when I turn the key. However when I hook up the jump starter i do get the key in the ignition ding...
  9. Oct 20, 2009 at 11:35 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sounds like a bad ALT. You should have a little ver 13V or greater at the battery when the car is running. Anything under that won't charge the battery.
  10. Oct 20, 2009 at 2:33 PM
    TBAGRR
    Md
    07 4x4 sport
    first start with the battery then go on to the other stuff, however the alt should put out around 14.4v however the coil is easy, its under the distributor, if you do replace it there is a spacer under bolt hole of the coil so make sure you dont lose them
