96 Supercharger upgrade or swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dedlish, Sep 16, 2018.
  1. Sep 16, 2018 at 1:18 PM
    Dedlish
    Dedlish [OP] Active Member
    Eric
    96 3.4L 4wd Tacoma
    3in lift
    So my 3.4 is leaking oil bad and burning oil too and i think it might have a coolant leak somewhere. I think this motor is on the way out and I was wondering if its more cost effective to rebuild and upgrade to a SC or find a Low mile TRD motor with the SC attached and just swap. Any info is helpful thx guys
  2. Sep 16, 2018 at 5:21 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Early v6 motors do not handle boost well, thus I don’t think you should go supercharging it.
    Maybe you can chime in @Speedytech7
    Luv my yota likes this.
  3. Sep 16, 2018 at 6:07 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    I believe it’s some crap dealing with the ecu on models from 95.5-97. Call LCE in AZ they should be able to point you in the right direction they’ve made a 5VZFE 500hp n/a and they’re a dealer for superchargers for our trucks.
  4. Oct 2, 2018 at 3:33 PM
    Dedlish
    Eric
    96 3.4L 4wd Tacoma
    3in lift
    Ive heard that the 96s had an. EGR and because of that you cant use the 7th injector kit from URD. Was wondering if I could swap a newer motor into it and get rid of the EGR so i could get the 7th. Thoughts?
  5. Oct 2, 2018 at 3:39 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Lots of engines had the EGR, even up to 2004. Depends on if it was a Cali spec car, or if it was one of those special 48 state federal trucks that came with it.
    My PreRunner was sold as a California spec'd model at the Fremont Toyota and had an EGR. My 5-Lug was sold in Sparks, Nevada and was 48 State Federal emissions spec'd. Both had EGR valves.
  6. Oct 2, 2018 at 3:57 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    just check if you have egr.
    95-96 ecus retard too much timing under boost. youl need to swap s 97 ecu in.
    i turbod my 96 a year ago. 100% worth it. truck rips now.
    BlackSportD, 1997tacomav6 and QMEDJoe like this.
  7. Oct 2, 2018 at 5:18 PM
    Dedlish
    Eric
    96 3.4L 4wd Tacoma
    3in lift
    Can the EGR be removed?
  8. Oct 2, 2018 at 5:18 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yeah. Little block off plate.
    Your issue isn't the EGR. It's your ECU not being able to handle boost effectively.
  9. Oct 3, 2018 at 2:57 AM
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    Did you put a later model ECM in or go with a stand alone? If you went with a different ECM, which model number did you use?
  10. Oct 3, 2018 at 3:03 AM
    Jcyr
    Jcyr Midnightthetaco
    Jack
    North east
    3RZ 04 4x4 black ext cab
    2.5" lift king/total chaos Skids sliders rear tire swing
    Just swap in a better motor platform like the 3rz or a 4.0 or a 2j
  11. Oct 3, 2018 at 6:03 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Depending on your wrench turning abilities you could always save some money and find one locally but you risk not knowing the history of the engine or you could spend the money with some reassurance that you have a top quality rebuilt engine. https://www.yotashop.com/toyota-3-4l-5vz-fe-v6/
    I’m sure they would have an ECM to go with the engine available or you could grab one off of these guys—->http://www.ranchotoyotatruckparts.com/
  12. Oct 3, 2018 at 8:57 AM
    devinzz1
    devin
    2023 aclb trd or mt
    97 ecu with an aem piggyback and progressive meth controller
  13. Oct 3, 2018 at 9:14 AM
    Trim taco
    There were a couple model numbers, even for '97, if I'm not mistaken.
    Can you be more specifc?
    Also, did you go with the F/IC 6? If so, would you mind if I PM some questions?
  14. Oct 3, 2018 at 12:21 PM
    devinzz1
    devin
    2023 aclb trd or mt
    97 ecu as long as it matches your drivetrain v6, auto, 4x4. you can use a 4runner ecu too i believe.
    i have a fic6 and a urd harness
  15. Oct 3, 2018 at 6:40 PM
    1997tacomav6
    Denver
    Yes a 1997 ECU works perfectly with no issues. 1995-1996 will not work supercharged with the original ECU.
  16. Oct 4, 2018 at 3:26 AM
    Trim taco
    So, here's my deal: I have a '96 and am trying to get everything ready for a supercharger. Currently I'm running too lean (LTFT in the 14 range) I bought an F/IC6 and boomslang harness with the hope of tuning in more fuel as well as simply getting an idea for what I was doing before I invest in a charger. Unfortunately, I couldn't get it to work (truck wouldn't start) I sent the F/IC in to be bench tested and AEM said it was fully operational, so I contacted Boomslang and they wouldn't give me the time of day, except to say that their product was not the problem. So I bought an ECM from a '97 #89661-04310 to see if my ECM just didn't like the F/IC. No luck, same problem, truck would crank and crank but never started. What I'd like to know is if there is another ECM I should be using or if (this is my theory) the wiring from Boomslang was somehow wrong. @devinzz1 are you willing to share your wiring diagram so I can check it against what I have?
  17. Oct 4, 2018 at 4:52 AM
    devinzz1
    devin
    2023 aclb trd or mt
    does the boomslang harness have the 2 resistors in the harness? see first link.
    https://www.tacomaworld.com/threads/how-to-aem-f-ic-6-install-tuning-and-help-thread.381830/
    https://people.well.com/user/mosk/images/Early_Tacoma_ECUs_v2.pdf
  18. Oct 4, 2018 at 5:17 AM
    Trim taco
    Boomslang harness came with no resistors. AEM gave me several options to try as far as resistors, none work. Maybe I'm understanding things wrong, but I was under the impression that the truck might throw codes/run poorly, but it should've at least started with the unit plugged in. I was never even able to start diagnosing problems.
  19. Oct 6, 2018 at 8:17 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    How do you do this with out having a code be thrown? I have mine blocked but P0401 gets thrown because it detects the pipe is blocked. Any way around this for 96 3.4L? For off roading of course:thumbsup:
  20. Oct 6, 2018 at 8:21 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You can bypass it with a resistor in one of the sensors, don’t remember which one exactly.
