96 Supercharger upgrade or swap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dedlish, Sep 16, 2018.
  1. Oct 6, 2018 at 8:24 PM
    1997tacomav6
    Denver
    Problem is you will not pass emissions if you do,
    96BlueTacos[QUOTED] likes this.
  2. Oct 6, 2018 at 8:29 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    Earth, 3rd planet from the Sun (CO)
    1996 Single Cab Taco Manual 4x4 3.4L V6 370k /1985 4Runner 4x4 22RE 200k /2001 Double Cab Taco Auto 4x4 Supercharged 3.4L V6 180k
    1996-JBA upper control arms, replaceable Cardan joint drive shaft, leveling kit, camper shell, trailer hitch... 2001- TRD Supercharged, TRD headers...
    off roader
    Edit; because yes most likely emissions wouldn't get passed
  3. Oct 6, 2018 at 8:33 PM
    96BlueTacos
    96BlueTacos トヨダ
    Mikey
    But I still just don't know how to make the code go away with the resistors I was hoping someone else has done this on the 3.4l
  4. Oct 6, 2018 at 10:30 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    The motors themselves do pretty well.
  5. Oct 6, 2018 at 10:36 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    What’s the most HP you can squeeze out of the 5VZ before it goes belly up?
  6. Oct 6, 2018 at 10:45 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    A buddy of mine got his to 420whp and it's been a daily. The oil pump recently gave up though, but the bearings seem ok so im not sure what its doing atm. 350whp seems to be the safe spot though with a decent tune. If you wanna be in the 400 range you need a really good tune, probably not something the FIC can give
  7. Oct 6, 2018 at 10:46 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    What do you think of twin charging?
  8. Oct 6, 2018 at 10:53 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    Kinda pointless imo on a stock setup. If you did running the s/c through the intercooler that would be preferable. But the capacity to make power on a twincharged setup would definitely surpass the stock internals. PLus with a somewhat properly sized turbo boost can be had at just 2000-2200rpm anyway. However there is a 4runner with that setup out there on youtube and I wont lie its pretty awesome!
  9. Oct 6, 2018 at 10:54 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Gotcha. Just thinking what if I want to do a 5VZ swap or turbo the 3RZ.
  10. Oct 6, 2018 at 11:00 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Go aftermarket crate motor , these usually have 2-3yr warranties and you can also have it built with better flowing cylinder heads, higher compression and much larger camshaft profiles
  11. Oct 6, 2018 at 11:01 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    If I was going crate, I'd want to go for that new Cummins drop in turbodiesel.
    My options are super limited here because of California, I'm sure you'd understand haha. I'd have to remove the turbo every two years.
  12. Oct 6, 2018 at 11:04 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    The 3rz seems to be more proven and cheaper to do but the 5vz is my personal favorite.
  13. Oct 6, 2018 at 11:04 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Have it built with CARB 50 state legal performance parts . You can build some serious hp using CARB legal parts
  14. Oct 6, 2018 at 11:06 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I have the 3RZ 4AT on my daily, and the 5MT Manual on my project truck. The 5VZ 5MT just feels infinitely more powerful than the 3RZ. I'd like to turbo the 3RZ one day, what's the most HP do you think I could push on my stock 3RZ block?
  15. Oct 6, 2018 at 11:07 PM
    #35
    BartMaster1234
    Tyler
    Flux Capacitor
    The whole engine swap thing is super complicated from a legal standpoint. Cummins crate is unreasonable because it's too expensive, but something like an LS7 could be made legal and is relatively cheap.
    My dream engine swap is a 2JZ-GTE out of a Supra.
  16. Oct 6, 2018 at 11:09 PM
    #36
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    LS engines is the way to go and now supercharged LT4 are gaining popularity
  17. Oct 6, 2018 at 11:11 PM
    #37
    BartMaster1234
    Tyler
    Flux Capacitor
    An LS7 out of a Z06 is what I'm thinking. Making it work with 4WD is the hard part.
    US Marine[QUOTED] likes this.
  18. Oct 6, 2018 at 11:14 PM
    #38
    Brice
    Brice Turbo Member
    Brice
    Texas
    A guy named speedfreak made 350hp reliably on the 3rz the swapped to an ls for the heck of it
  19. Oct 6, 2018 at 11:14 PM
    #39
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Should be able to work !!
  20. Oct 6, 2018 at 11:16 PM
    #40
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    They've Got 650hp supercharged LT4 crate motors going for $14k
