96 T100 turn key...silence.
Discussion in 'Toyota Trucks & SUVs' started by jessea1a, Nov 16, 2011.
  1. Nov 16, 2011 at 8:15 AM
    jessea1a
    jessea1a [OP] Shoeless
    Jesse
    Port Angeles, WA
    '96 T100 SR5 3.4L V6 4x4
    Painted wheels, emblems, bumpers, and mirror backs black.
    Ok so I've got a 1996 3.4L V6 T100 (150k miles). Few weeks ago I got in to drive home from work and when I turned the key nothing happened. So far I have:
    -replaced starter (with a brand new one)
    -replaced blown fuses
    -new battery (cleaned terminals)
    Still getting nothing when I turn the key and not sure where to turn to next. Suggestions?
  2. Nov 16, 2011 at 8:16 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Do you get any power at all when you turn the key? Lights, blower, windows, etc...?
    Fink
  3. Nov 16, 2011 at 8:20 AM
    jessea1a
    Jesse
    Port Angeles, WA
    None, unless its hooked up with jumper cables, so the new battery drained, but still can't start it up. Lights etc. all work fine with cables hooked up.
  4. Nov 16, 2011 at 8:22 AM
    Fink
    Orlando, FL
    That's strange.
    You've verified that both ends of the battery cables are hooked up and making good contact, correct?
    Fink
  5. Nov 16, 2011 at 8:26 AM
    jessea1a
    Jesse
    Port Angeles, WA
    Exrtremely strange. Yeah I tightened them up after I cleaned them.
  6. Nov 16, 2011 at 8:32 AM
    Fink
    Orlando, FL
    I would wait for some electrical guys to find the thread and maybe they can chime in with some thoughts.
    Brand new battery, good connections...sounds like it should work to me.
    Fink
  7. Nov 16, 2011 at 8:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Can you jump start it, if so, will it stay running?
  8. Nov 16, 2011 at 9:05 AM
    jessea1a
    Jesse
    Port Angeles, WA
    Even with a jump it won't start, but all the electricals work. I'll turn the key and get one click, then nothing.
  9. Nov 16, 2011 at 9:42 AM
    T-Rex266
    T-Rex266 Elon Musk Moderator
    Subd for outcome
  10. Nov 16, 2011 at 9:43 AM
    Fink
    Orlando, FL
    :pccoffee: :typing:
    Fink
  11. Nov 16, 2011 at 9:48 AM
    Pugga
    Massachusetts
    Do you have a battery tender? If so, try putting that on charge for a little bit and see if you can at least get enough juice in the battery to make it turn over (disconnect it from the truck since it seems the truck is discharging the battery, even when it's off). Might seem trivial but you need to isolate the problem, right now there are too many possibilities.
  12. Nov 16, 2011 at 9:53 AM
    jessea1a
    Jesse
    Port Angeles, WA
    The battery tender we've got on base is busted...that was the first thing we tried when she wouldn't start the first time. If it was just the battery shouldn't it turn over just fine via jumper cables?
  13. Nov 16, 2011 at 10:19 AM
    krap22
    krap22 Well-Known Member
    Do you have a multimeter? i would first start with the voltage across the battery(should be something around 12-13v with out it running). Then i would find the connection to the starter and see if you have power there. You should get the same V there as long as there is a good connection.
  14. Nov 16, 2011 at 10:31 AM
    jessea1a
    Jesse
    Port Angeles, WA
    Yeah I'm sure there is one hiding somewhere. I'll get out there this evening if the rain lets up at all...we know the new starter is getting power because my buddy got shocked by it. :rolleyes:
    The battery might be drained in which case I'll swap it with another one and see if that works.
  15. Nov 16, 2011 at 10:39 AM
    Fink
    Orlando, FL
    If there is any chance the battery is drained, then I would definitely make sure it is charged. That's an obvious one, but it sounds like there is a chance that it's dead - which would cause what you are describing.
    Fink
  16. Nov 16, 2011 at 10:45 AM
    BrettBretterson
    BrettBretterson Wild Ginger
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    No, this is a common misconception. If your battery is toast, just hooking up cables to another car won't provide enough juice to jump yours. It will provide enough juice to run your lights, but not start the car.
    If your battery alone provides no starter clicks upon turning the key, but you do get a click on jumper cables, your battery is done. You need to at the very least fully trickle charge your battery, but likely need a brand new battery altogether. It sounds to me like your alternator might need replacement too.
  17. Nov 16, 2011 at 11:00 AM
    jessea1a
    Jesse
    Port Angeles, WA
    Ahh good to know this, thanks. I guess the new battery drained because I hooked it up, (stupid move) forgot to disconnect it and left it sitting there until the new starter arrived? I'll try a different/new battery and see if that helps. Likely any grounds might be shot? This seems like an electrical problem...not my forte. Neither is mechanical but hey...:rolleyes:
  18. Nov 16, 2011 at 11:29 AM
    Pugga
    Massachusetts
    Beat me to it about jumping a car with a completely dead battery.
    The post about the multi-meter is a good diagnostic also.
  19. Nov 16, 2011 at 11:57 AM
    BrettBretterson
    Bothell, WA
    06 DCSB TRD OR 4x4
    5100's
    It is possible that you have grounding issues, but unlikely. It sounds like you've just got either a bad alternator or bad battery. Or both now if your battery died due to a failed alternator. Unfortunately unless you can get either tested by a shop, you're in a bit of a chicken and egg situation.
    A shop or auto parts store can test the alternator to see if it is providing charge, and can load-test the battery to see if it is failing. I just noticed where you are, and it looks like you may be a bit detached from either...but are there any auto repair or parts shops in Neah Bay at all??
  20. Nov 16, 2011 at 12:06 PM
    jessea1a
    Jesse
    Port Angeles, WA
    There aren't any in Neah Bay, but I live in Port Angeles and there are shops and AutoZone, etc. I'll pull out the battery and alternator and get those tested this weekend. Thanks for all the responses guys, very helpful!
