96 Taco only starts with starter fluid
Discussion in '1st Gen. Tacomas (1995-2004)' started by Guam96taco, Sep 14, 2021.
  1. Sep 14, 2021 at 5:50 AM
    Guam96taco
    Guam96taco [OP] Member
    1996 Tacoma 4x4 (3.4)
    My 1996 4x4 Tacoma (3.4 engine) only starts when applying starter fluid and banging on the gas tank a couple times. It stays on and runs normal. When I turn the truck off and start it up again it turns on no problem. However, when I let it sit for an hour or two, im back to square one where it cranks but wont start. Hard to tell if my fuel pump turns on when I place the key in on position because I live by the main highway.
    Not sure when was the last time fuel filter was changed but looks pretty old.
    If I can get some guidance on where to start. Truck has roughly 195k miles. Timing belt was recently replaced last month.
  2. Sep 14, 2021 at 5:55 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    Fuel pump only runs while cranking and running.
    Guam96taco[OP] likes this.
  3. Sep 14, 2021 at 6:16 AM
    Guam96taco
    You have anything in mind that may be causing the issue?
  4. Sep 14, 2021 at 6:17 AM
    1997tacomav6
    Denver
    Start with fuel filter
  5. Sep 14, 2021 at 6:19 AM
    Black DOG Lila
    Virginia
    What he said ∆ ∆ ∆
  6. Sep 14, 2021 at 6:21 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I think try swapping the horn relay with the fp relay (but I could be wrong- hopefully someone will chime in on this) Good luck
  7. Sep 14, 2021 at 6:24 AM
    Guam96taco
    Thanks guys. I'll swap out filter tomorrow and hope for the best.
    Black DOG Lila likes this.
  8. Sep 14, 2021 at 7:10 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Most likely the pump especially if the filter is very dirty. It will stress the pump pushing fuel thru a dirty filter. Usually runs for a bit after the filter is replaced then the pump dies. Based on age and miles is replace the pump also
  9. Sep 14, 2021 at 7:47 AM
    Guam96taco
    Even if truck doesn't die out after getting it started? Truck runs fine once it's fired up with starter fluid. Sorry not really knowledgeable in cars. New to this.
  10. Sep 14, 2021 at 7:58 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    The 'banging on the tank' screams fuel pump to me. It's old and tired, and has trouble getting started, but once it's moving, it will keep moving.... for now. I would expect that you'll start to find that as time progresses, it requires more banging, and likely provides lower fuel pressure with a resultant loss of power. If/when you change the pump, ensure you blow through the lines, at least as far as the filter, and replace the filter as well.
  11. Sep 14, 2021 at 8:04 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    IAC valve or fuel pump relay and or fuel pump ignitor. Just another guess in the thread. Banging on the tank is interesting. Like was said, could be a tired pump or lose/corroded wire.
  12. Sep 14, 2021 at 9:00 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Just curious what is this fuel pump relay as I have never seen one ( Nor can I find it on my 2000 EWD) is this something new that replaced the Circuit Opening Relay that I am used to from my mid eighties engines?
    If this was the Circuit opening relay I would say the crank side of the relay was out .
    As OP says it runs fine once started
  13. Sep 17, 2021 at 1:44 AM
    Guam96taco
    Ran a scan on truck and it's giving me P0340 (Camshaft position sensor). Gonna try my luck and replace CPS.
    stevesnj and Steves104x4 like this.
  14. Oct 7, 2021 at 8:45 PM
    Guam96taco
    Replaced cam shaft sensor, fuel pump and fuel filter. Truck started fine right after replacing and was able to start about 4 more times as I went to different places. The next morning, it's giving me the same issue, crank no start...
  15. Oct 8, 2021 at 6:38 AM
    Glamisman
    Glamisman Well-Known Member
    unfortunatly this is the point in time where you need to find a tech that has a PICO scope and knows how to use it.
