96 taco xtra cab gauge cluster
Discussion in '1st Gen. Tacomas (1995-2004)' started by Stlhorsecowboy66, Apr 14, 2011.
  1. Apr 14, 2011 at 3:45 PM
    Stlhorsecowboy66
    Stlhorsecowboy66 [OP] Active Member
    Kevin
    Ft Collins Co
    96 taco
    Arb front bumper, bilstien 5100/w elbach coils, trail gear rock sliders(that i hate by the way)
    I have a 96 taco, I must have the basic gauge cluster,(no tach). Has anyone tried to change the cluster to one that has the tach in it and does it work and read correctly. And same question for that little clock to the right of the steering wheel. Any help would greatly appreciated, thanks Kevin.
  2. Apr 14, 2011 at 6:12 PM
    trdracing5
    trdracing5 Well-Known Member
    Elizabeth City, NC
    1995 Tacoma 4X4
    ARE Impulse Shell, BFG AT KO's
    Good luck finding one with a tach. I have been looking for one forever. It seems that most from 95-97 came with the "basic" gauge cluster. You also need to make sure that you get one from a vehicle with the same transmission as your vehicle.
  3. Apr 14, 2011 at 7:16 PM
    Stlhorsecowboy66
    Kevin
    Ft Collins Co
    96 taco
    would a cluster from a 1 gen double cab be the same. I really do not want to add an after market one on the dash. I guess i will be visiting Jim's yota yard in Denver to do some looking around. thanks for the help
  4. Apr 15, 2011 at 6:17 AM
    JeffsJeep04
    JeffsJeep04 Well-Known Member
    Jeff
    Menomonie, WI
    2010 DCSB SR5 V6
    The clock is easy. Pop out the blank panel and pop in the one with the clock in it. The wiring for it is plugged into the back of the blank. That was the first thing I did to my new taco. Probably paid way too much for the clock on ebay ($70), but it was worth it to just drop it in, have the right color back light, and be done with it.
  5. Apr 15, 2011 at 6:59 PM
    Stlhorsecowboy66
    Kevin
    Ft Collins Co
    96 taco
    Thanks Jeff, I have a yota yard located here in colorado, I'm going down on saturday to check it out and see what they got that I can not live with out.
  6. Apr 16, 2011 at 6:51 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    No.
    '96 = cable-driven speedometer
    1st gen DC = '01 - '04 = electronic speedometer
  7. Apr 16, 2011 at 4:50 PM
    Stlhorsecowboy66
    Kevin
    Ft Collins Co
    96 taco
    yea i learnt that to day.I can find the cluster with tach, if I had a 5 speed. I'm just going to have to keep checking back.
  8. Apr 17, 2011 at 5:21 AM
    trdracing5
    Elizabeth City, NC
    1995 Tacoma 4X4
    Like I said earlier I have been looking for one FOREVER. Someone mentioned to me before about trying one out of a 4Runner. I have not looked at them carefully enough to know whether a 4runner one would work in the Tacoma.
  9. Apr 17, 2011 at 7:22 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    So ... Your Taco is an automatic?
    Is the auto shifter on the floor or on the column?
    If it has a column shifter, you may have to decide if you can live without the PRNDL indicator lamps in the cluster.
  10. Apr 17, 2011 at 8:57 AM
    Murrfk
    Murrfk Well-Known Member
    Manitoba, Canada
    1996 Tacoma 2.7l
    I have a pretty basic 96 tacoma, and it came with a tach. Don't all 5speeds have tachs? I think if you have an automatic that would be the reason for no tach in yours.
  11. Apr 17, 2011 at 11:28 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    No.
  12. Apr 17, 2011 at 1:01 PM
    JeffsJeep04
    Jeff
    Menomonie, WI
    2010 DCSB SR5 V6
    My 96 had bucket seats, the chrome trim package, AC, and alloy wheels...but no tach.
  13. Apr 18, 2011 at 6:54 PM
    Stlhorsecowboy66
    Kevin
    Ft Collins Co
    96 taco
    I was told that the 4runners are e,ectronically drive speedo's so the won't work either. I was toldthat a 5speed cluster would work but u would loose your o/d light and your ect light. And yes mine is a auto and one the floor.
  14. Apr 18, 2011 at 7:08 PM
    trdracing5
    Elizabeth City, NC
    1995 Tacoma 4X4
    I am not sure that it is totally correct that all 4Runners are electronically driven. Here is a pic from ebay of a 1997 4runner cluster. It looks (at least to me) very similar to the tacoma cluster.
