96 tacoma 2.7 runs rough and sputter
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chadr7858, Jun 25, 2014.
  1. Jun 25, 2014 at 8:57 PM
    Chadr7858
    Chadr7858 [OP] Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Hey everyone I just bought a 96 2.7 l that has 131000 miles. When I bought it, it had a check engine light on for p0171 lean fuel mixture on bank one. The truck ran totally fine got it home no problems. I had taken off the battery cable to reset the computer and now it has no light on idles totally fine but when I drive it, it has no power sputters and runs rough. I was wondering what you guys think could be the problem. I have checked the maf and it's clean and the throttle body looks a little dirty but not horrible. The air filter is dirty and will replace it tomorrow to see if it help what would you guys do? The previous owner said that his mechanic said that the computer was messed up but the code is for lean fuel mixture.
  2. Jun 27, 2014 at 12:09 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'd bet that the catalytic converter is clogged, can cause those symptoms. Also never a bad idea to change spark plugs and wires. Good Luck
    Sent from my HTC One using Forum Fiend.
