96 Tacoma 3" rear lift help!
Discussion in '1st Gen. Tacomas (1995-2004)' started by MapleMoose, Aug 31, 2011.
  1. Aug 31, 2011 at 2:40 PM
    MapleMoose
    MapleMoose [OP] Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    So im getting ready to swap out my 3" blocks and stock springs for a "real" lift.
    This is what im getting:
    -All Pro 5 pack 3" springs
    -Bilstein 5125
    -Spring relocation mounts
    -U-bolt flip kit
    -Shock relocation mounts
    Because my truck is a 96, i have to relocate the front spring mount 2" forward... Correct? Do i just cut out the old mount, measure 2" forward and weld the new one on? How precise does it have to be?
    And because of the u-bolt flip kit i also have to relocate the shock mounts onto the axle. Where do i relocate it? And do i have to relocate the top mount too?
    Any tips and ideas would be great!
    Thanks
  2. Aug 31, 2011 at 2:48 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Here is my U bolt flip kit install http://www.tacomaworld.com/forum/1st-gen-tacomas/156849-1st-gen-u-bolt-flip-kit-install.html
    And with moving the spring mount forward yes it has to be spot on or your shackle angle will be off. I what i would do it draw a line on the center line of the front bolt hole and measure 2" forward draw another line and line up the center line of the new mounts bolt hole and tack in place. Do heavy tacks and put the springs on and the axle. Drop the truck on it's own weight and check the shackle angle. It should be about 75* to 80* to the back when on level ground. NOTE when putting the truck back down and the springs just tacked put jack stands under your frame about a 1/4" to 1/2" lower then the frame just in case the tacks fail.
  3. Aug 31, 2011 at 3:04 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    When i relocate the spring mount towards the front, do i have to worry about the frame arch? Because they are already mounted pretty close to that arch.
    Now about the u-bolt flip, can i just relocate the bottem mount to the axle and forget about the top mount?
  4. Aug 31, 2011 at 3:13 PM
    JLee
    Jerry
    Bay Area NorCal
    You know I've never done it and I'm not at my truck right now so I can't run out and look.
    And the shock mounts if you keep the top mounts your shock angle will be over 40* they are mounted at 30* stock. Also they will lose about 1.75" stroke because the lower mount is moving up. I would weld a cross member across the frame and weld in new upper mounts so you can chose your shock angle and stroke length. Another thing wait until your done with the install to order your shocks or buy 10" stroke and build off those.
  5. Aug 31, 2011 at 4:07 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    Hmm... I think im getting in way over my head. Maybe ill just scrap the flip kit and cut the long u-bolts down.
  6. Aug 31, 2011 at 4:10 PM
    JLee
    Jerry
    Bay Area NorCal
    It's really not that hard I did mine in a few hours at a mod day none the less. I think the relocation of the shocks freaks everyone out that's why you don't see many 1st Gens installing the flip kit.
  7. Aug 31, 2011 at 10:20 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
    why not just get the expo leafs?? i asked Allpro if they would bolt right up to my 96 and they said yes...unless they were wrong?? :notsure:
  8. Aug 31, 2011 at 10:26 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
