96 tacoma 4x4 , can u adjust the idle?
Discussion in '4 Cylinder' started by adiablo420, May 27, 2009.
  1. May 27, 2009 at 5:58 PM
    adiablo420
    adiablo420 [OP] Active Member
    HI DESERT CALIFORNIA
    96 TACOMA 4X4 4 CYL
    SUSPENSION LIFT, RIMS AND BFG MUD TERRAINS
    Idle runs kind of low. When i start my truck, its so low, sometimes it stalls when not warmed up. Plus when i gas to go , it hesitates cause its getting itself out of the low idle as i go, but doesnt stall on me. Just think the carb needs to be adjusted,.
  2. May 27, 2009 at 6:45 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
    No carb on your truck. Its fuel injected. Undeer your hood, on the bottom of it, there should be a lable stateing the idle adjustment...:)
  3. May 27, 2009 at 9:17 PM
    adiablo420
    96 TACOMA 4X4 4 CYL
    probably the throttle body is what is see then.. thanks . ill check it out..
