96 Tacoma Automatic door locks - help
Discussion in '1st Gen. Tacomas (1995-2004)' started by n_georgia, Jun 1, 2008.
  1. Jun 1, 2008 at 5:49 PM
    n_georgia
    n_georgia [OP] New Member
    Calhoun Georgia
    96 Tacoma SR5 ext cab
    2 inch lift
    I have a 96 tacoma and everytime I crank it up the door automatically lock. I live on a farm and get in and out alot. This really gets on my nerves. Is there anyway to disable this without killing the power to the normal door locks?
    thanks, Ryan
  2. Jun 1, 2008 at 7:19 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I was under the impression that they could be programmed to not lock when the engine is started, but Im haveing a difficult time find ino to back it up. Here's a bump for ya.
  3. Jul 26, 2008 at 1:02 PM
    n_georgia
    Calhoun Georgia
    2 inch lift
    anybody????
  4. Jul 26, 2008 at 3:13 PM
    T man
    T man Member
    vermont
    08 trd 4x4
    fold-a-cover,trd seat covers,scan guage,hood protector,vent visors
    I have a program that worked on an 04 that I had.I have know idea if it will work on a 96 but give it a shot.
    Start with the key out of ignition,drivers door open,other doors closed.Next,insert key into ignition turn ignition from lock to on 5 times ending at on.(at this time ecu should make lights flash once and buzzer chirp once)next close-open-close drivers door(this turns automatic lock function off)next turn ignition back to lock.Lights flash twice and your done. .Hope this works for you.
  5. Jul 26, 2008 at 9:45 PM
    n_georgia
    Calhoun Georgia
    2 inch lift
    mines sort of weird, it does it 85% of the time probably has something to do with being a 5 speed. But if the doors are closed and you crank it up the doors automatically lock. When you turn it off they unlock. This is my first toyota and I have also noticed that when you unlock the drivers door with the key it unlocks but you can let it go and turn it again and it will unlock the passengers on the second turn.
    Thanks for any help. Ryan
  6. Jul 28, 2008 at 7:44 PM
    backwoodking
    backwoodking Well-Known Member
    Thousand Oaks/Southern CA
    3.4 V6 Deck Plate and Cut Turn-Down
    Deck Plate, Hitch, Cut Turn-Down Exhaust, Tint, Clear Corners, Shell, Full Size bed in the pickup, Hopefully More Soon
    I had that same thing on my 2000. There was a program like described by Tman that is in the owner's manual to change that. I dont have the owner's manual on me, but I could get back to you with the way to change it.
  7. Aug 4, 2008 at 5:05 PM
    747 function > form
    1st Gen.
  8. Aug 4, 2008 at 5:12 PM
    nlt2836
    nlt2836 Member
    Arizona
    08 PreRunner SR5 Offroad
    Viper 350 HV, Alpine IDA-X001, PAC SWI-Jack, ARE Tonneau Cover, Bedrug
    This sounds like a function of an aftermarket alarm or keyless entry??? If the door is open when you start the truck do the doors lock?
  9. Aug 4, 2008 at 8:56 PM
    n_georgia
    Calhoun Georgia
    2 inch lift
    no they do not lock if you crank the truck with the door open, I will try this out tomorrow and let you know guys.
