96 Tacoma bad body damage. Straight frame.
Discussion in '1st Gen. Tacomas (1995-2004)' started by skatzboard, Jun 22, 2016.
  1. Jun 22, 2016 at 12:32 AM
    skatzboard
    skatzboard [OP] New Member
    truckee ca.
    crumpled coke can
    320,000 miles on frame and body 3.4 v6 70,000 miles Auto trans changed to 5 speed with 100,000 miles Trutrack rear diff Fox shocks 2" suspension lift Icon upper control arms 31x10.5 bfg ta km2s Vanillaroma tree air freshener Magnaflow exhaust Custom pvc cup holder Duct tape Sawzall surgery Trail gear rock sliders
  2. Jun 22, 2016 at 12:39 AM
    skatzboard
    truckee ca.
    crumpled coke can
    3.6 and 5 speed are relatively new and it has 2.5 fox lift fox coilovers icon upper control arms trutrack rear diff 4.1 gear. Rock sliders. (Not coming off) hahaha.
    Any body ever taken an older body and put it on Tacoma chassis motor and drivetrain? The body is fxxked why not?
  3. Jun 22, 2016 at 12:45 AM
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    Get a regular cab body... that'll be a fun ride being much lighter than the access cab.
    skatzboard[OP] likes this.
  4. Jun 22, 2016 at 1:13 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It will be some work but not impossible .
    Your talking about a pick up body older then 95 ?
    The only thing that comes to mind is the cab wiring which would be like any swap with the option to make an adapter harness or just repin the Tacoma plug for the fourth ECM plug
    The other would be the fuel filler access being on the right instead of the left.
    Since the work would be quite different I can`t say what would be more labor intensive swapping the body and cab or putting your good parts on another Tacoma
  5. Jun 22, 2016 at 1:21 AM
    imom
    CAL
    2014 Regular Cab
    No... because before 95 1/2 model...it wasn't a Tacoma...I was talking about gen 1 Tacoma regular cab. Access cabs always had longer wheelbase and more weight. The regular cab is more car like so it handled better and weighs less... The most fun I had in a regular cab was being in a new Syclone, but that's a different beast all together. I think the regular cab with a 3.6 motor would have plenty of power and extra mods available from the 3.6 motor...would make it a fun build with what parts he has already.
  6. Jun 22, 2016 at 1:24 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I could not say I have never owned a 3.6 engine.
    Regular cab would be no big deal except the cab wiring and moving some body mounts
  7. Jun 22, 2016 at 1:29 AM
    imom
    CAL
    2014 Regular Cab
    OP has a motor with 70K on it...seems to be still good unless the accident did a whammy on it... but getting a regular cab with a good frame and body and transfer over the parts would make it a unique truck. Unfortunately the gen1 are holding their value considering it's an old freaking truck... could be a good low cost swap. Other option is to find an access cab with a rusted frame, but good body and do the swap.
  8. Jun 22, 2016 at 7:17 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    If you can find one a 5speed cab swap would be pretty straight forward. Youl have to modify an autos body to accept clutch pedal.
    Oh and your trucks a 3.4.
