96 Tacoma cab mounts
Discussion in '1st Gen. Tacomas (1995-2004)' started by louied817, Jun 20, 2015.
  1. Jun 20, 2015 at 6:27 PM
    louied817
    louied817 [OP] Well-Known Member
    So I have a 96 regular cab with rusted out mounts to the point that the cab is resting on the frame....I know i need to replace brackets that weld to frame.
    Looking for options of how to raise the cab enough to do what I have to without taking everything apart/off. Anyone done this before? Maybe not to the extent of mine but a how-to or idea to raise the bed would be appreciated.
    Thanks much!!
  2. Jun 20, 2015 at 10:17 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You should have enough room to lift things being real careful and with help to watch you don`t put pressure on things as you lift .
    Once the mounting hardware is removed.
    This was on my 2000 Tacoma there might have been a few other things I disconnected been a year or two
    Your truck should be close to the same might have some slight differences.
    This allowed me enough room to remove the old mounts on the frame and install new ones.
  3. Jun 22, 2015 at 5:44 AM
    louied817
    What is best way to raise the cab? One side at a time? With some wood and a jack?
    6 mounts total on this I believe. 2 on both sides and two in front?
  4. Jun 22, 2015 at 12:58 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    I've used a jack and wood blocks. Just be sure you don't lift it too far since there are a lot of things connected under there.
  5. Jun 22, 2015 at 5:53 PM
    louied817
    Seems to be the common idea. Thank you
    Any idea where i can get stock cab mounts including bolts and nuts?
  6. Jun 23, 2015 at 11:51 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I bought mine at my dealer .
    If you don`t deal local any of the online Toyota parts vendors
