96 tacoma dies when warmed up
Discussion in '1st Gen. Tacomas (1995-2004)' started by ericwebb, Mar 14, 2017.
  1. Mar 14, 2017 at 5:45 PM
    ericwebb
    ericwebb [OP] New Member
    eric
    Hi i have a 96 tacoma 2.7 4x4. It ran fine till the other day i was driving it and it just died like i had turned the key off. I had it towed home and got to checking and i could only get it started by unplugging the maf sensor. so i thought i had found my problem so i purchased a new sensor. Plugged new sensor in and it started right up. But after letting it set and idle for about 20 min it done the same thing like you just turn the key off and no restart. Now about the only way i can get it to start is let it set for about an hour hit it with some ether and it will start right up and run just fine for about 20 min idling then shuts back off. Any suggestions would be great as this is my daily for work. Thanks in advance.
  2. Mar 14, 2017 at 6:21 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    It could be the cam-position sensor, or crank-position sensor.
  3. Mar 14, 2017 at 6:23 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Unplug your intake air sensor and see if it stay running. They have a history of failing and the computer can't compensate for air density at running temp and then just looks out.
  4. Mar 14, 2017 at 6:26 PM
    tan4x4
    Rick
    Folsom, CA
    I think OP already did that.
    ericwebb[OP] likes this.
  5. Mar 14, 2017 at 6:31 PM
    Speedytech7
    I meant the temp sensor not the MAF, on 95-97 they are separate sensors.
  6. Mar 14, 2017 at 6:44 PM
    tan4x4
    Rick
    Folsom, CA
    Thanx for the clarification. :oops:
    ericwebb[OP] and Speedytech7 like this.
  7. Mar 15, 2017 at 12:17 PM
    ericwebb
    eric
    Okay so i unplugged the air sensor and got it running and its been running for about an hour now at idle. So if that fixed my problem do you recommend a new temp sensor or will a new one do the same thing. Thank you guys for replying.
    Speedytech7 likes this.
  8. Mar 15, 2017 at 12:21 PM
    Speedytech7
    You're talking about the temp sensor in the side of the air filter box correct? If so I can get you a link to a new one.
  9. Mar 15, 2017 at 12:22 PM
    ericwebb
    eric
    Yes i am thank you
  10. Mar 15, 2017 at 12:26 PM
    Speedytech7
  11. Mar 15, 2017 at 12:56 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Why not test the sensor before replacing? Test the resistance across the terminals.
  12. Mar 15, 2017 at 12:57 PM
    Speedytech7
    Normally I'd suggest the same, but this is a rather common problem with this sensor specifically.
  13. Mar 16, 2017 at 12:34 AM
    DrZ
    Mesa, AZ
    96 2.4L 5-speed
    It only takes a minute to check it if you have the chart of temperature vs. resistance. I'm curious how it fails without throwing a code. The code usually means open or short, so it would have to be way off but not completely open or shorted.
