'96 Tacoma Headlight Upgrades
Discussion in 'Lighting' started by Stoffregen Motors, Dec 7, 2011.
  1. Dec 7, 2011 at 10:03 AM
    Stoffregen Motors
    Stoffregen Motors [OP] Active Member
    Cool, CA
  2. Dec 7, 2011 at 6:30 PM
    joes06tacoma
    Joe
    Central Coast, CA
    http://www.rallylights.com/detail.aspx?ID=744
    If you are looking for light output only, buy these and upgrade the bulbs and wiring harness. I had them on two previous trucks and really wish I could get a set to fit my current truck. I had 80/100watt bulbs and a custom harness I put together to handle the extra amp draw. As long as they were aimed right, no one ever flashed me, and they made the extra 130W off road lights I had completely unnecessary.
    A buddy has them on a Jeep he owns. Even with a lift and 90/100watt bulbs he has no problems with glare for oncoming traffic.
    As far as style....that's your call. I know the newer factory lights don't have the potential for good output that you have now with your current setup.
    BTW-Your link says 4x6 size lights. I am ALMOST certain that you want 5x7 size. Also known as 200mm. Fits all square headlight Tacos up till 97 I believe. Double check me, but I used to sell auto parts and I have a pretty good memory.
    Some will chime in and recommend HIDs. I don't know much about those, but the quality seems to be hit and miss. For the price, hard to go wrong with the Hella conversions. You can have the lights, upgraded bulbs, and harness for under 200 bucks and they should be reliable for you. I did seem to burn out the 80W low beams fairly frequently. You can also get a 55W (stock wattage) low beam that will still put out ridiculous light compared to what you have now. Technically not street legal, but neither are HIDs.
  3. Dec 7, 2011 at 7:37 PM
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); mattgecko's Underhood Lighting; ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BlendMounted BEL Vector 995; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    x2! I ran a set of these on my '92 Pickup, and loved them - Highly recommended!
  4. Dec 8, 2011 at 8:56 AM
    Stoffregen Motors
    Cool, CA
    Great! I like the look of the newer lights, but I thought I would get better performance from the sealed beam style.
    Did you buy their wiring upgrade or make one? I see they offer two wiring upgrades, one with separate relays. Sky's the limit with new separate Bosch style relays...
  5. Dec 8, 2011 at 5:30 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I made my harness. I used twelve gauge wire from the battery, to each relay (high/low), then twelve gauge out to the lights and back to ground. The only issue I had is I could not find h4 plugs with 12 gauge wire leads. So the last couple of inches of wire is 14 gauge at the lights. That isn't a problem, I just was going for minimum voltage drop at the lights. Ran the truck for six years like that with no issues.
    There are cheaper harnesses out there. My buddy has one on his Jeep that was around 30 bucks. It's been fine, no failures. Check Summit and Jegs and see if they have one and what they want for it. There may be a vendor on Tacoma World that carries them too, not sure.
    If you do it, be sure you get the correct harness for a Toyota. I think the first gen Taco is negatively switched, the second gen is positive (normal).
  6. Dec 8, 2011 at 5:36 PM
    Mexicant
    Mexicant Well-Known Member
    B
    Crawlerado
    Braap
    Or if you don't want to drop the coin for the hella setup Amazon has the silverstar's for $18 a piece. Much better than the stock factory headlights.
  7. Dec 8, 2011 at 5:44 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
  8. Dec 8, 2011 at 8:20 PM
    Norton
    Monument, CO
    I was happy with stock wattage bulbs on stock wiring. The "lenses" provided a very nice upgrade over stock headlights.
  9. Dec 8, 2011 at 8:31 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This is a good point. Might be best to just stay with the stock wattage at first. You might not even want more at that point. I was happy with the low beam especially. But if you ever do want more, I'm telling you the first time I tried the 100w high beams I was like: "damn!" :D
  10. Dec 8, 2011 at 10:11 PM
    Stoffregen Motors
    Cool, CA
    I live in the mountains and BRIGHT lights is a must. My wife's Scion Xb has the best headlights I've ever seen. I had originally thought HID, but you guys are making some good arguments. $110 for a pair of good lights, plus $35-$100 for wiring.
    I would like to run a good reverse light too. Like these which I have mounted on customer's trucks. http://visionxsuperstore.com/SolsticeSolo2SquareLEDLight35WideBeamXIL-S1101.aspx
