96 tacoma help
Discussion in 'General Tacoma Talk' started by Tater11, Oct 30, 2023.
  1. Oct 30, 2023 at 7:32 AM
    Tater11
    Tater11 [OP] New Member
    96 tacoma 4cyl straight drive 4wd
    My truck idles fine but when I give it a little gas the motor races ... also one of the pulley wheels is chirping tho not sure which one. Have to shift gears early because the rpms go high quickly?
  2. Oct 30, 2023 at 7:38 AM
    Clearwater Bill
    Billy
    Largo Florida
    Slipping clutch?
    That takes in person diagnosis to confirm. Also could be just the belt.
    In gear or in neutral? What does 'race' mean to you? If in gear, see first question. If in neutral, examine the throttle cable for proper routing and tension
    rocknbil likes this.
  3. Oct 30, 2023 at 7:43 AM
    Tater11
    So the rpms are fine until I let off the clutch... then just a little gas and the rpms go to the point where I usually shift up... no clutch slippage
  4. Oct 30, 2023 at 7:45 AM
    Tater11
    There is a slight rattling sound when clutch is engaged?
  5. Oct 30, 2023 at 8:02 AM
    Clearwater Bill
    Billy
    Largo Florida
    You mean engage the clutch, correct?
    RPMs rising much faster than the vehicle is moving?
    *IF* I have the above right, still sounds like clutch slippage to me. As in pretty toasty.
    Bivouac and rocknbil like this.
  6. Oct 30, 2023 at 10:14 AM
    rocknbil
    rocknbil Well-Known Member
    Bill
    2003 Taco Ext Cab DLX TRD 4WD MT 3.4L
    How long has it been since you changed them? I had this, even with new belts, so I incrementally kept tightening the alternator pulley (even though it was to deflection spec,) the chirp decreased each time then went away. Drove me nuts because it only happened on startup and when cold.
  7. Oct 30, 2023 at 10:14 AM
    Tater11
    Yes it' should be much faster mph
