96 Tacoma problem 5vzfe
Discussion in '1st Gen. Tacomas (1995-2004)' started by CodysTT, Apr 26, 2015.
  1. Apr 26, 2015 at 11:15 AM
    CodysTT
    CodysTT [OP] New Member
    Hey guys I'm having an issue with my Tacoma v6 5vzfe motor. Just to give you an idea my truck blew a headgasket about 2 months ago.I Bought a gasket kit, pulled the heads and had them checked for cracks which they were fine but they were warped so I had them machined. Also since I was in there I bought a timing belt set with a new water pump and thermostat. flushed the coolant system and put everything back together. All fluids were topped off and the truck fired right up. Got it up to operating temperature but it kept climbing. So I thought maybe the New thermostat wasn't working properly so I changed it. Still the same. Bought another water pump. Changed the clutch fan. Still the same. I'm to the point where I'm lost as to what is going on. Everything was done by the book. HELP a brother out!!!!!
  2. Apr 26, 2015 at 11:22 AM
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    Did you make sure that was not any debris left behind in any of the coolant ports with all the work that was done?
  3. Apr 26, 2015 at 11:24 AM
    TacomaJunkie8691
    WA State
    Check to make sure you don't have any obstructions blocking coolant.
  4. Apr 26, 2015 at 6:22 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Did you get an OEM thermostat? Try pulling it to see if this still happens.
  5. Apr 26, 2015 at 6:58 PM
    trx125
    trx125 Well-Known Member
    Did you install the thermostat the right way? Burp the system with the heat on max and front end(radiator) higher than the back of the motor to remove air pockets and such?
  6. Apr 26, 2015 at 7:00 PM
    trx125
    Have to done a pressure test to see if you still have a leaking head gasket?
