96 Tacoma transfer case
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bigbuck1999, Feb 22, 2020.
  1. Feb 22, 2020 at 2:29 PM
    Bigbuck1999
    Bigbuck1999 [OP] Well-Known Member
    1996 Tacoma, 2017 TRD off road
    Guys quick question, I should be able to pull the transfer case without pulling the transmission correct? Also What are the two sensors on the transfer case one is missing a plug on the end the one closest to the rear of the transfer case.
  2. Feb 22, 2020 at 2:38 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Can only answer about the sensors; has to do with the vacuum actuator on an ADD system (4x4). Supplies a signal to the actuator to let it know that the transfer case is in 4x4 or 4x2.
    Others will chime in with the rest though I'm sure a search will yield the results you need
    *goes on a search*
  3. Feb 22, 2020 at 2:50 PM
    Bigbuck1999
    Any idea exactly what it’s called I tried looking online but not having much luck.
