96 Tacoma V6 Engine Quits
Discussion in 'Performance and Tuning' started by nomadd, May 22, 2012.
  1. May 22, 2012 at 7:11 PM
    nomadd
    nomadd [OP] Member
    damon
    reno, nv
    96 tacoma extra cab lx
    Truck runs normal at 0 to45 mph with rpms below 2000. As soon as I accelerate with rpms over 2000 engine sputters and dies. After 2 or 3 minutes engine starts right up again and runs fine till I accelerate over 2000
    + rpms and then dies again. I took it out the other day and drove it 50+ miles, accelerating slowly,keeping rpms under 2000 and it ran normal,but as soon as I stepped on the gas to speed up it dies.
    I appreciate any guesses
    nomadd
  2. May 22, 2012 at 7:16 PM
    mick478
    mick478 He is The STig
    Bott
    Stockton, CACA
    2011 White TRD Sport, 4x4 doublemint cab
    Ome 885 coils Ome n9000 front shocks Ome n182 rear shocks K&n drop in filter Duratracs Kenwood kac 90210d Kicker 12" Alpine 800 watt 4 channel Pioneer 430w 6x9 Firestone ride rite air springs
    well, could be a lot of things, for starters, any sheck engine lights? code could point, vaguely, in the proper direction. this could be anything from a broken vaccume line to a faulty fuel pump. If no cels, check fuel pressure at injectors, i hear 5-10psi will define a good pump from bad, thats all i got, good luck!
    --bott
  3. May 22, 2012 at 7:17 PM
    mick478
    Bott
    Stockton, CACA
    also, had a dude who has a rebaged s-10 who had a faulty maf sensor go bad, but hopefully that would throw a cel,
  4. May 22, 2012 at 7:19 PM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    I once had an old truck that acted just like that. Starting with the easiest remedy, I replaced the inline fuel filter and it ran fine afterwards. Good luck!
  5. May 22, 2012 at 7:21 PM
    mick478
    Bott
    Stockton, CACA
    Clogged fuel filter or injectors also
  6. May 22, 2012 at 7:39 PM
    nomadd
    nomadd [OP] Member
    damon
    reno, nv
    I had a cel a couple of times when it started to die and I stepped on the gas. It died anyway. After a couple of minutes it started. I cleared the cel and it stayed off. I thougth cel came on because I had drowned the engine.
    Thanks for your quesses
  7. May 22, 2012 at 7:42 PM
    mick478
    Bott
    Stockton, CACA
    hook it up to one of them doodads that reads the zeros and ones, and see if the code is still stored, worth a shott
  8. May 22, 2012 at 7:58 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you have a ScangaugeII or Ultra Gauge, use that to see if you have any codes. I doubt that you have codes, and or have either of those gauges. Other wise, stop by Autozone, and ask them to check and see if you have any codes.
    Next, how many miles do you have on your truck? When is the last time that you replaced the fuel filter?
    When is the last time that you changed your oil and spark plugs?
  9. May 23, 2012 at 7:40 AM
    nomadd
    nomadd [OP] Member
    damon
    reno, nv
    I blew fuel filter out with air. It didn't seem to be plugged. Oil is new. Spark plugs are 7 yrs. old . I have 172,000 miles on it. O'Riellys checked battery and alternator. Thy're ok. I'll try new plugs and fuel filter.
    Thanks
  10. May 23, 2012 at 7:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    With that many miles, when is the last time that you replaced the catalytic converter/converters?
    Quite possibly very clogged. If I remember correctly, aren't the cats unboltable?
  11. May 26, 2012 at 8:43 AM
    nomadd
    nomadd [OP] Member
    damon
    reno, nv
    A new fuel filter seems to have solved my problem.
    thanks again!
    nomadd
  12. May 26, 2012 at 9:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Always the easy things. :thumbsup: Glad you are back up and running. Not boost it. ;)
