96 Tacoma won't engage in 4wd
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kjhunter, Sep 17, 2014.
  1. Sep 17, 2014 at 7:10 AM
    Kjhunter
    Kjhunter [OP] New Member
    Keefer
    Quincy, CA/Missoula, MT
    [96 Stock Tacoma 3.4][89 Pickup Cam'd 22re]
    I've searched the forums and not found much that pertains to my problem. I have a 1996 sr5 3.4l manual trans and transfer case, 4wd is add. I changed the clutch and now my pickup won't engage in 4wd. All vacuum lines are connected except for the lower end of the breather hose. The sensor in the transfer case is plugged in and the fuse is good. Any help would be appreciated.
  2. Sep 17, 2014 at 9:45 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    wont engage as in you can't get the t case in 4wd or the front diff won't slide over?
  3. Sep 17, 2014 at 12:02 PM
    Kjhunter
    Keefer
    I can shift the transfer case and I get 2lo. I just can't get the front diff to engage.
  4. Sep 17, 2014 at 1:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Check all your vacuum lines and electrical connectors. It's super easy to miss the electric connectors on top of the tranny.
    Your positive the diff isn't working? Like you have had it off the ground to watch the wheels turn?
    You can also check the actuator
  5. Sep 17, 2014 at 3:40 PM
    Kjhunter
    Keefer
    I haven't jacked it up but I put it up on a hill and rear tire was spinning with nothing up front. I'll go back and have to double check it out. Any tips on how to test the actuator? The 4wd light doesn't come on so maybe there is no signal going to the actuator when the transfer case is in 4.
  6. Sep 18, 2014 at 9:27 AM
    bawilson21
    bawilson21 Well-Known Member
    Bryan
    WA
    00 SR5 V6 4x4 5-speed
    Rear Diff Breather Extension Deck Plate Mod 31" Destination A/T 3" Body Lift Rancho 5000 Shocks Grey Wire 7Pin Tow harness
    Good time to do the Grey-wire mod if you havent yet. I had issues with re-seating my J-shifter correctly when I replaced my clutch.
  7. Sep 18, 2014 at 11:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    If the light isn't coming on. A connector is not hooked up right is my guess. Very easy to miss since you can't see shit on top of the tranny anyways haha been there
    96s didn't have e lockers. Well..VERY few did.
  8. Sep 18, 2014 at 4:30 PM
    Kjhunter
    Keefer
    Swapped the transfer case plugs around and there she went. Four wheel drive is working fantastic.
    I wish a had a rear end that I could grey-wire mod.
    Mabel96Lola06 likes this.
  9. Sep 18, 2014 at 9:32 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sweet. Glad it worked out.
  10. Mar 5, 2024 at 3:19 PM
    Mabel96Lola06
    Mabel96Lola06 Member
    96 Tacoma 2.7l 2006 Tacoma 4.0L
    2006- cold air intake, headers/exhaust, 6 inch lift, regeared for 35s
    I just put a different engine in my 96. Having the same issue. What do you mean you swapped the transfer case plugs??
  11. Mar 7, 2024 at 12:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    probably had them plugged into the wrong sensors.
