96 trd supercharger install
Discussion in '1st Gen. Tacomas (1995-2004)' started by toogodbetheglory, Dec 7, 2014.
  1. Dec 7, 2014 at 12:53 PM
    toogodbetheglory
    toogodbetheglory [OP] Member
    So i searched and searched and still haven't seen a clear answer on what exactly I need for installing a trd supercharger on my 96 taco. It seems like the the best way to do it is to get a different ecu.
    -If i do get an ecu off a newer tacoma does it have to be a ecu off a 4x4 ?
    -once I do get a newer ecu is it necessary to get the URD fuel upgrade?
  2. Dec 7, 2014 at 1:06 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    This depends on where you live. Closer to sea level, the leaner you'll run, the more you'll need to add the URD 7th.
    Closer to mile high living, the more you can get by without it.
  3. Dec 7, 2014 at 6:10 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    I thought I read for the 95.5-96 Tacos guys replaced all 6 injectors with the larger ones and skipped the 7th one all together.
  4. Dec 7, 2014 at 6:29 PM
    tomtom
    The Desert SW
    2012 FJ
