96 vs 2002 3.4 differences.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wulf, Apr 6, 2016.
  1. Apr 6, 2016 at 12:36 PM
    Wulf
    Wulf [OP] no brain just damage
    rock raisin
    I am trying to pick up a used motor to replace the one in my truck rather than rebuilding it due to budget constraints. I have come across a 2002 with around 120k on it and have the chance to pick up the motor fairly cheap.
    My truck is a 96 3.4 with a 5 speed and the truck it is coming out of is a 2002 3.4l prerunner.
    AFAIK the 2002 is drive by wire whereas my 96 is drive by cable. Are there any differences that would prevent me from swapping the throttle bodies?
    Are all of the other sensors/accessories interchangeable?
    Thanks
  2. Apr 6, 2016 at 2:32 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    My '02 is not drive by wire. It has a cable and I think all '02s are that way. I'm pretty sure that Toyota made that change late in the '03 model. For sure, the '04 v6 models no longer had the throttle cable.
    There were definitely differences in ECUs between the '96 and '02. Also, there were no prerunners in '96. Some one else more knowledgeable than me can speak to what differences there may be, if any, in the transmissions.
    @Blackdawg
  3. Apr 6, 2016 at 5:56 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Emissions was different too. The 96s used a vacuum box up front on the drivers side. The later 01-04s had it moved to above the gas tank.
    Catalytic converters changed too. Only one on 95-00 and there are two on 01-04s.
    Should be able to just drop the motor in though and wire it up. Nothing else was a drastic change.
  4. Apr 6, 2016 at 7:32 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I purchased a 02 3.4 for my 96 4runner and i read that the lower intake & injectors are different. Just use your intake & injectors/fuel rail assembly. Ex. manifolds & rear ex crossover pipe are different also but the 96 parts will bolt onto the 02 with no issues.
  5. Apr 6, 2016 at 9:37 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I think the older engines still used a cap and rotor distributor system for the ignition before they switched to a coil ignition on the newer models, but don't quote me on that, I may be thinking of the T100.
  6. Apr 6, 2016 at 9:43 PM
    Digiratus
    Roaming the PNW
    The RedHead
    This is not correct. No 3.4L ever came with a distributor. All of them are coil pack ignition.
  7. Apr 6, 2016 at 9:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea the 3.4l 5vzfe was also coil packs.
    Its the 2/3rz 4 cylinder that changes. The 2rz is distributor, the 3rz is coilpacks.
  8. Apr 6, 2016 at 9:49 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    injectors never changed. Intake only had a reservoir type thing added to it. ITs the same otherwise.
    OP, basically, as long as you just swap the motor itself(the block) and run your 96 ecu and everything else, you'll be totally fine.
  9. Apr 7, 2016 at 4:35 AM
    68dave
    Dave
    I'm just quoting what my local Toyota dealer parts guy told me and what i've read here. A member here said he did the same swap and was getting a CEL and it ended up being the injectors.
  10. Apr 7, 2016 at 6:01 AM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    Not exactly. The 3rz and 2rz were distributor until some time in '97, then I believe both switched to coil packs. My Taco is a '96 3rz with a dizzy.
  11. Apr 7, 2016 at 10:13 AM
    Wulf
    rock raisin
    I went to see the donor today and ended up buying the motor. Only had 131k on it and it sounded super healthy. Oil looked good, coolant was perfect.
    Didn't realize how poorly mine runs until I heard it.
    68dave likes this.
  12. Apr 7, 2016 at 10:29 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Injectors changed, there are the blues and the browns with different part #'s and prices.
  13. Apr 7, 2016 at 10:47 AM
    68dave
    Dave
    Yep. That's what i mentioned earlier. I read that here and my local Toyota dealer parts guy confirmed it for me. I had a 96 4runner with a seized 3.4, i purchased a used 02 3.4 for the swap.
  14. Apr 7, 2016 at 10:51 AM
    Dirty Pool
    99 XCAB V6 MT TRD
    Yep, just backing you up. Old Catonsville man here.
    68dave[QUOTED] likes this.
  15. Apr 7, 2016 at 10:58 AM
    68dave
    Dave
    Thanks. I knew they were different, i was waiting for some back up!
  16. Apr 7, 2016 at 11:06 AM
    Wulf
    rock raisin
    I've know the injectors are different but they should be interchangeable. I talked to someone who put a 2004 motor in his 97 and he said there was no issue
  17. Apr 7, 2016 at 11:27 AM
    68dave
    Dave
    Yea, my post I mentioned that they have to be changed. I used the 96 intake, fuel rail & injectors. Everything bolted from the 96 engine to the 02 engine.
  18. Apr 7, 2016 at 12:00 PM
    Dirty Pool
    99 XCAB V6 MT TRD
    There is definitely an issue somewhere, be it with the manifold and/or forward vs backward compatibility, not sure.
  19. Apr 7, 2016 at 12:56 PM
    Wulf
    rock raisin
    Well, I guess I'll figure it out along the way ¯\_(ツ)_/¯
  20. Apr 7, 2016 at 1:01 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Not really, the 2/3rz both were dizzy until mid 97, then they switched to coil pack, then again in 01 they switched to coil on plug.
