96 vs 2002 3.4 differences.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wulf, Apr 6, 2016.
  1. Apr 10, 2016 at 8:53 AM
    #41
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Yeah took so much longer to remove lol
  2. Apr 10, 2016 at 3:06 PM
    #42
    Wulf
    Wulf [OP] no brain just damage
    rock raisin
    the exhaust manifolds are also different
  3. Apr 10, 2016 at 3:25 PM
    #43
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Yea i mentioned that. But it's a easy swap other than those couple things..
  4. Apr 11, 2016 at 11:26 AM
    #44
    Wulf
    rock raisin
    ah, I must have missed that.
    What's interesting is that the older manifolds have a larger internal diameter all the way through the collector. The performance difference is probably negligible though.
    Didn't get the new motor dropped in because I had to drive all over town to pick up the necessary gaskets and some smaller hardware. Hopefully it goes in next weekend.
  5. Apr 11, 2016 at 1:24 PM
    #45
    Wulf
    rock raisin
    I just called and talked to someone at URD and he said the injectors are the same, just made by different companies after 1998 or whenever the part number switched.
    Edit: the newer injectors are rated at 14.9 ohm, the older ones are 14.3 ohm. Source, 1996 used #23250-62030, 2002 used #23250-62040.
    According to the FSM for 1996, the injectors should be in the 12-16 ohm resistance range, so they should be fine as long as they are in proper condition.
  6. Apr 17, 2016 at 12:17 AM
    #46
    Wulf
    rock raisin
    took all of 5 minutes to drop the motor in. Spent several hours fighting to get the transmission mated. Can't get it the last 1/2" or so
  7. Apr 18, 2016 at 6:20 PM
    #47
    Catcrazed
    Catcrazed Love is Dogs and Toyotas
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    91 Flatbed, 4.88's, ARBs, SAS, 3.4 Swap, 35s, M8000, lots lights, Aux tank, Protech
    So the brown injectors drop in place of the older ones? Any one know of a good place to buy reman injectors I have an intermit misfire and I've already replaced coils and wires w oem.
  8. Apr 20, 2016 at 4:09 PM
    #48
    Wulf
    rock raisin
    theoretically yes, I have not personally verified.
    You can check your injectors using a multimeter if you suspect that they are bad
  9. Apr 20, 2016 at 4:57 PM
    #49
    Catcrazed
    Bryan
    Central Oregon
    3rd Gen Flatbed 3.4
    The problem with my setup is does it very intermittently like 2 days ago I drove about 20 miles got my tires put on and when I about an hour later started to leave and it was missing low on power and then let it sit overnight drove it around all day yesterday for five different stops and never had a problem at all so I think that they'll pass on the multimeter unless I wait until it's actually missing and then just start pulling the plugs to the injectors and you can only reach 3 so then I have to take the intake off swap which side they are on and wait for it to do it again
  10. Apr 24, 2016 at 9:50 PM
    #50
    Wulf
    rock raisin
    Got the truck up and running. No CEL for the injectors or anything else :bananadance:
    spaustia, 68dave and Digiratus like this.
  11. May 1, 2016 at 1:41 PM
    #51
    Wulf
    rock raisin
    Any idea what would cause random stalling? The truck occasionally stalls in neutral or in gear. Today it stalled on me on the highway and I had a close call :eek:
    It stalls and all the dash lights come on but after coming to a stop it restarts without any CEL :annoyed:
  12. May 1, 2016 at 2:03 PM
    #52
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Even if it starts back up without and CEL, the CEL that came on when it stalled will still be stored in the ECU...maybe try pulling it and see what code(s) it gives you? That would be the best place to start
  13. May 1, 2016 at 4:54 PM
    #53
    Wulf
    rock raisin
    if it's throwing a code the light would stay on, yea?
    Rechecked all of the engine bay electrical connectors and found that the MAF connector was only about 95% of the way on and the pass head ground was loose, hopefully that was the issue. If not I'll try pulling codes
  14. May 1, 2016 at 4:56 PM
    #54
    eon_blue
    Azusa, CA
    Not always, no...my truck has had an intermittent CEL going on and off for a couple weeks now, P0171 System Too Lean code. It stays on for a few days then goes off for a day or so. When I took it to Toyota, the light was off, but they said they were able to pull the code from the truck's ECU memory and diagnose it that way.
    The problem is still there, it's just worse at times than others. I'm still in the process of getting it fixed.
