96 won't start. One click
Discussion in '1st Gen. Tacomas (1995-2004)' started by Norcolgreg, Oct 19, 2016.
  1. Oct 19, 2016 at 8:40 AM
    Norcolgreg
    Norcolgreg [OP] New Member
    96 tacoma
    I replaced the starter and the battery. I get one click..
    I'm stumped
  2. Oct 19, 2016 at 10:42 AM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    I would double check all the connections...battery,starter, etc.
    Jaysjammin and Mush Mouse like this.
  3. Oct 20, 2016 at 12:10 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Check that your battery cables arent super corroded up under the sheathing! Thats some what common... Since you already replaced the battery and starter it seems as though not enough power is reaching the starter so there has to be something there not allowing a good flow of current!
  4. Oct 20, 2016 at 12:31 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    What were the symptoms BEFORE you replaced the starter and battery? Same one-click?
    And WHERE is the one click coming from?
  5. Oct 20, 2016 at 1:38 PM
    DrZ
    DrZ Well-Known Member
    Mesa, AZ
    96 2.4L 5-speed
    Also check the ground wires from the block/head to body and body to battery.
  6. Oct 25, 2016 at 6:49 AM
    Tucker771
    Tucker771 Tacoma Beast
    Tucker
    Raleigh, NC
    2004 Tacoma Doublecab 4x4 TRD
    Gray wire mod, 4" coil lift, 2" block lift+2" AAL, rear air bags, re-located trailer wiring plugs, trail gear front bumper, kicker sound w/pioneer in-dash, 8" kicker sub, airaid MIT kit, trail gear rock sliders, arrow antenna, blacked out grille, HID kit, Smittybilt 8k winch, extended brake lines, LED overhead lighting, LED turn signals, Explorer Rock Lights, removable doors, Re-wired 4x4, Roof Rack
    wiggle battery cables
    Jaysjammin likes this.
  7. Oct 25, 2016 at 7:01 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    it sure sounds like not enough juice getting to the starter somehow
