97 2.4 no power no start, good battery
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoShlamaco, Mar 29, 2025.
  1. Mar 29, 2025 at 4:04 PM
    TacoShlamaco
    TacoShlamaco [OP] New Member
    97 2.4 tacoma
    Newbie here! I’ve got a 97 2.4l 2wd Tacoma, in automatic. It drives and runs fine, until last night. I go to start it up and get no crank, no lights on dash and just a single click sound. I thought it may be the battery, so I check with a voltage meter to verify that it’s got a charge and it’s reading 12.78v. So maybe my ignition switch is bad? So I turn key to on position, I get lights on the dash! Try to crank it, nothing, not even a click. So maybe it’s my ignition switch I think. I turn key to on position, and jump bank 3-5 on the starter relay spot. Nothing. My brain tells me it could be the starter, but I am also not getting brake lights or headlights when turned on with key in on pos or without key in cylinder at all. And when I turn the daytime running lights on, I get a buzzing noise coming from the fuse panel in the hood. I took the buzzing relay out, turn headlights completely on and it starts buzzing then but not when drl’s are on. Do you guys have any ideas, maybe you can prevent me from throwing random parts at it. I’ve got a voltage meter so let me know what I should test. TIA!
    Edit: also I forgot to add, I cannot shift it out of park with the key in on pos to maybe try to neutral start. All of these problems started when I tried to start it last night.
  2. Mar 29, 2025 at 4:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Does the horn or the windshield wipers work?
    Dm93 likes this.
  3. Mar 29, 2025 at 7:14 PM
    TacoShlamaco
    97 2.4 tacoma
    The horn does, wipers do not work with key in and on.
  4. Mar 29, 2025 at 7:38 PM
    TnShooter
    Deogee
    STOCK
    Have you checked the 40A AM1 Fuse?
  5. Mar 29, 2025 at 7:42 PM
    TnShooter
    Deogee
    STOCK
    Under the hood.
    Should be #28 (if the online diagrams are right)
  6. Mar 29, 2025 at 8:02 PM
    TacoShlamaco
    97 2.4 tacoma
    It looks like it’s good, no splits in the copper inside of it which I can see by eye. The cover came off of it when I tried pulling the fuse out… oops.
  7. Mar 29, 2025 at 8:23 PM
    TnShooter
    Deogee
    STOCK
    Do you have a voltage meter. or test light?
  8. Mar 29, 2025 at 9:11 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  9. Mar 30, 2025 at 1:27 AM
    TacoShlamaco
    97 2.4 tacoma
    Yes to both
  10. Mar 30, 2025 at 10:05 AM
    TnShooter
    Deogee
    STOCK
    I’d want to check for power to that fuse.
    Since the top came off, just reach down and touch the copper to test.
    That fuse feeds the brake lights and wipers. As well as the stater relay fuse.
  11. Mar 30, 2025 at 12:09 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Miles on your ignition switch?
