97 2.7L misfire help please
Discussion in '1st Gen. Tacomas (1995-2004)' started by adt0423, Apr 23, 2012.
  1. Apr 23, 2012 at 9:05 AM
    adt0423
    adt0423 [OP] Well-Known Member
    Alex
    Harrisonburg, VA
    1997 Tacoma 4x4 ext cab. 2021 TRD Off Road AG DCSB
    1997 - 2 in level kit, 31" tires, aluminum tool box.
    My truck is stuttering when i go to accelerate. Right after i shift gears and hit the gas(its 5 speed not auto) It stutters and shakes for about 10 secs and then goes fine. been doing this for about 2 weeks. finially today it happened thru 2nd and 3rd and my check engine light came on. Guy at autozone said it came up as random misfire and told me to replace my whole ignition system. im thinking just plugs and wires. any other opinions or advice as to the problem?
  2. Apr 23, 2012 at 9:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What was the code number?
  3. Apr 23, 2012 at 9:10 AM
    medic2230
    Murph
    Bama! Roll Tide
    My 2000 would do that it did it for a while and I never did figure out what was causing it. It eventually stopped doing it but, I never threw a CEL.
  4. Apr 23, 2012 at 9:11 AM
    adt0423
    Alex
    Harrisonburg, VA
    he didnt say. just told me it was a random misfire. and that it was probably my ignition system. can the ignition system cause that problem? i had the ignition go out in my last car and it just wouldnt run period it didnt stutter like this
  5. Apr 23, 2012 at 9:12 AM
    adt0423
    Alex
    Harrisonburg, VA
    the check engine light blinked a few times like it wasnt sure if it even wanted to come on but eventually decided it did...
  6. Apr 23, 2012 at 9:31 AM
    seksilumpia
    seksilumpia Well-Known Member
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    Performance mods: TRD CAI, AFE throttle body spacer, Doug Thorley headers, TRD exhaust. Cosmetic mods: HID 10k head+3k fog lights, BHLM, T-rex 2 eyelids, billet grill (5 piece), 20% front window tint, 4% back window tint, tinted 3rd brake light, altezza tail lights, LED license plate lights, door skid protectors, slotted drilled rotors,plasti dip rims,painted rotor and drums. Interior mods: TRD seat covers, LED map and dome lights, 2 kicker 10' w/ 500 watt amp, pioneer door speakers,and Pioneer AVIC X930BT.
    when this happened to me,it was a misfire due to a bad ignition coil..you need that code though or you wont know where its coming from..usually when it blinks,it may very well be the catalytic converter
  7. Apr 23, 2012 at 10:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    IIRc, the 97 still has a distributer, right?
  8. Apr 23, 2012 at 11:21 AM
    adt0423
    Alex
    Harrisonburg, VA
    thanks for the help guys. if i get that code you think you could give me a more definite answer? or should i still start with plugs and wires?
  9. Apr 23, 2012 at 12:26 PM
    adt0423
    Alex
    Harrisonburg, VA
    ok so i got a p0304 code. went to a diff. autozone this time, this person told me that it was most likely plugs and wires.
  10. Apr 23, 2012 at 3:13 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    P0304 - Mis-fire in cylinder #4
  11. Apr 23, 2012 at 6:03 PM
    robbo1965
    robbo1965 Member
    Robert
    Spring, Tx
    96 lx
    Time for new wires and plugs. Just my 2 cents.
  12. Apr 23, 2012 at 6:18 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    This
  13. Apr 24, 2012 at 12:19 PM
    seksilumpia
    Brandon
    El Dorado Hills
    05 TRD Sport DCSB
    they may very well be a distributor cap. Im not too familiar with the older gen tacomas. This happened to my 2000 land cruiser and my 2005 tacoma,both are ignition coils. But get it fixed right away OP,youre not saving any money just by not fixing it now,you would be saving up for a headache. good luck!
  14. Apr 24, 2012 at 3:37 PM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    Start with the plugs but use Platinum (cheaper) or Iridium, they don't work better but they last longer. Run some seafoam through the fuel and vacuum system, can't hurt.
  15. Apr 24, 2012 at 7:22 PM
    adt0423
    Alex
    Harrisonburg, VA
    ima do plugs and wires when i get paid thursday(soonest i can with the terible stroke of luck ive come into). If that doesnt remedy the problem I'll move onto ignition system and other components. I really appriciate the help. I'll be in contact prob friday whether or not it fixed it. :) thanks again
  16. Apr 25, 2012 at 7:38 PM
    TacomaJPP
    TacomaJPP To secure peace, is to prepare for war
    East TN
    03 4WD TRD XTD Cab
    Snugtop Camper Brushguard
    97s were a split year. Half with distributor, half with distributorless. My February of 1997 truck was distributorless. The ones made in January, had one....okay, so maybe not half and half.
    If it is with, plugs, wires, cap, button. If it is without, sounds like a coil pack.
  17. Apr 26, 2012 at 11:29 AM
    acirco
    acirco SEARCHER
    Alan
    Omaha, NE
    2000 Tacoma Reg. Cab, 2.7L4cyl., 5-spd, 4x4
    NONE
    Do the plugs and wires first. I just had this happen with #1 misfire code and it was the plug wire. Cap and rotor too if you have them. If it still happens it is probably a coil, either way a new coil warrants new wires, plugs, cap and rotors but this way you can limit wallet damage one piece at a time.
  18. Apr 28, 2012 at 6:02 PM
    adt0423
    Alex
    Harrisonburg, VA
    Denso plugs and ngk wires did the trick. truck is running better than ever. thanks for the help guys!
