97 2wd rear end specs?
Discussion in '4 Cylinder' started by dylangunit, Dec 8, 2009.
  1. Dec 8, 2009 at 10:32 AM
    dylangunit
    dylangunit [OP] Member
    Dylan
    Kentucky
    97 2wd tacoma
    Chip,exhaust,intake,lowered.
    i have a 2wd 97 tacoma, its a 5 speed witha 2.4l im pretty sure my ratio is 3.42 right now, but im gettin ready to take it to a 4.10 ratio and put a different differential in it. i need to know everything about this rear end before i buy the parts like.spline count on axles, size of ring gear,and where to buy the parts.please help me my rear end is knocking and i need to fix it asap.
  2. Dec 8, 2009 at 10:36 AM
    98tacoma27
    Ben
    Not Beech Creek
  3. Dec 8, 2009 at 10:40 AM
    dylangunit
    Dylan
    Kentucky
    97 2wd tacoma
  4. Dec 8, 2009 at 10:40 AM
    98tacoma27
    Ben
    Not Beech Creek
    Toyota Differential Code Decoder - Vehicles with 4Txxxxxx...VINs
    First Position - Diameter of ring gear
    A = 7.5"
    B = 8"
    Positions 2 & 3 - Ratio
    01 = 3.42
    02 = 3.58
    03 = 4.10
    04 = 4.56
    05 = 3.15
    06 = 3.91
    Final Position - Differential type
    A = 2 Pinion, Open
    B = 4 Pinion, Open
    C = 2 Pinion, OEM Limited Slip
    Cristiang19 likes this.
  5. Dec 8, 2009 at 10:43 AM
    dylangunit
    Dylan
    Kentucky
    97 2wd tacoma
    thanks alot
  6. Dec 8, 2009 at 10:44 AM
    98tacoma27
    Ben
    Not Beech Creek
    Why are you going to 4:10's? Do you plan on lifting (bigger tires)?
  7. Dec 8, 2009 at 10:47 AM
    dylangunit
    Dylan
    Kentucky
    97 2wd tacoma
    my vin is 4TANL42N3VZ259352
  8. Dec 8, 2009 at 10:47 AM
    dylangunit
    Dylan
    Kentucky
    97 2wd tacoma
    no i want a faster take off for racing
  9. Dec 8, 2009 at 10:50 AM
    dylangunit
    Dylan
    Kentucky
    97 2wd tacoma
    idk how to find the ratio and differentail type using the vin?
  10. Dec 8, 2009 at 10:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    There should be an axle code in your door jam sticker.
  11. Dec 8, 2009 at 7:03 PM
    dylangunit
    Dylan
    Kentucky
    97 2wd tacoma
    i checked there too its the same vin that is on my dash
  12. Dec 8, 2009 at 7:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Can you take a pic of the sticker on the door jamb? Post it up, and we can disipher the code for ya.
  13. Dec 8, 2009 at 7:35 PM
    blackxpress
    blackxpress Well-Known Member
    Jeff
    Carlisle, OH
    98 SR5 2WD Xcab
    I'll be curious to know how it works out. How soon will you be you doing this? My 98 has a 3.42 2 pinion open diff and I've been thinking about going to a 4.10 LSD but I'm not sure I really want to. In my case I'm thinking it might help it do a little better job towing my boat, especially on steep ramps. I've been hesitating because the truck does a pretty good job as it is and gets 28 mpg hwy unloaded. It's my daily driver and I run on the hwy a lot so I don't want to risk screwing up my hwy performance and fuel economy unless I think it'll make a huge difference in towing performance. Keep us posted. Or, if others of you have made the same mod I'd like to hear about it.
  14. Dec 8, 2009 at 7:59 PM
    dylangunit
    Dylan
    Kentucky
    97 2wd tacoma
    i just posted a pic of the vin off of my door in my pictures on here.
  15. Dec 8, 2009 at 8:00 PM
    dylangunit
    Dylan
    Kentucky
    97 2wd tacoma
    and to blackxpress, it wouldnt get as good of fuel milage with the lower gear ratio. but it would definitely pull better.
  16. Dec 8, 2009 at 8:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Need the whole sticker. Cant see the gear code in that pic.
  17. Dec 8, 2009 at 8:01 PM
    dylangunit
    Dylan
    Kentucky
    97 2wd tacoma
    ok sorry i got ill put it on here now
  18. Dec 8, 2009 at 8:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You have an A01A (lower right on the sticker)
    7" 3:42 gears, 2 pinion open diff.
  19. Dec 8, 2009 at 8:08 PM
    dylangunit
    Dylan
    Kentucky
    97 2wd tacoma
    do you know if my axles would fit in a 4wd rear end?
  20. Dec 8, 2009 at 8:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont think they will.
