97 4runner trail rated rear axle shafts?
Discussion in '4Runners' started by Fenwick1993, Nov 15, 2013.
  1. Nov 15, 2013 at 5:43 AM
    Fenwick1993
    Fenwick1993 [OP] Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2 2nd Gen T4R's
    So much Yota I can't explain!
    I'm looking for a set of trail rated rear axle shafts for a friend's 97 4runner with ABS, yukon gear, and a few others have shafts, but it doesn't look like anything for ABS. Anybody have any ideas? Also this truck has the slit case differential.
  2. Nov 15, 2013 at 6:13 AM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Calgary
    2006 Campster Mobile
    My truck is MAGIC
    Trail rated?
    These are toyotas not jeeps :p
    How big are his tires? Unless he running 38s or up, the factory axle shafts should be more than enough. Lots of people run 37s with no problem. Hell, people are even running 40s on stock axle shafts.
  3. Nov 15, 2013 at 6:30 AM
    JWaldz
    JWaldz Gone Crawlin'
    Waldo
    Colo Springs
    99 4Runner LTD
    The only "trail rated" axle shafts you are going to find are chromoly.. Regardless, he's most likely going to lose ABS.
    Poly Performance 95.5-04 Tacoma Rear Axle Shafts
    However, unless he is seriously having issues with his current stock axle shafts he's wasting his time. Like spoonman said above me, stock ones would still be ok with 37's. Anything larger though you're pushing it.
    Has he looked at the possibility of a full float conversion?
    FROR Full Float Conversion
    FROR Full Float Conversion Completed Kit
  4. Nov 18, 2013 at 12:37 PM
    Renaud33
    Renaud33 Well-Known Member
    I love it. :D
  5. Nov 18, 2013 at 1:19 PM
    Fenwick1993
    Not Fenwick
    Chesapeake, VA
    I didn't type it, my buddy did. xD
    He's figuring now that he'll just buy stock ones, because he doesn't want to lose ABS. The ones on the truck now are very torn up- the splines have been stripped off the ends.
