fabrication and 97/99 plow truck on a hot-dip galvanized frame
Discussion in '1st Gen. Tacomas (1995-2004)' started by ColinD, Mar 29, 2023.
  1. Mar 29, 2023 at 1:43 PM
    ColinD
    ColinD [OP] Well-Known Member
    Minnesota
    97 Tacoma SR5 V6
    I completed this project last summer and figured I'd throw some photos up here in case anyone is interested.
    We've been plowing snow with a '99 3.4L SR5 for many years on our family farm in Minnesota. Nice maneuverable little truck, gets down sidewalks and into tight areas like our loading docks better than a 1-ton truck. I fabricated some wings a few years ago to minimize the spillover at the edges of the 6.5' Meyer blade, which really improved the truck's efficiency (although, you have to stay on top of plowing if the snow accumulation is particularly heavy, or the lightweight truck will struggle to push the volume the blade is capable of.)
    It had the typical 1st gen frame rust issues, and I had the box off a couple times to patch the frame behind the cab. Eventually, the frame beneath the cab was pretty compromised, and the steel was beginning to buckle behind the front suspension attachment points.
    I found a clean '97 3.4L SR5 in Salt Lake City a couple years ago - apparently the owner had moved from Atlanta to Utah and brought the truck with him, and then it suffered a mechanical failure. (It had a reman Jasper engine in it; when I disassembled it later, I found it had swallowed an intake valve.) I had just completed revamping my F-650 with air ride suspension, flatbed, and a wheel lift, and had been planning on taking a shakedown road trip out to Vegas for the SEMA show, rather than flying. Got together with the Tacoma owner, made some plans, exchanged funds on the way out, and scooped up the truck on the way home.
    When I got home, I carefully disassembled the '97, sandblasted the frame, reinforced it with 3/16" plate, and welded some sturdy plow mounting gusset plates to the front of the frame. I palletized the frame, crossmembers, gas tank skid plate, hitch, spare tire brackets, plow mount, etc. and dropped it off with AZZ Galvanizing in Winsted, MN. A couple weeks later, they had run all the parts through their facility and I was able to begin reassembly.
    I used the engine, automatic trans, TRD/Kazuma LSD, cab and engine wiring harnesses, and ECM from the '99, and used the frame, cab, and box from the '97. I had to order new OME lift springs for the rear (due to the difference in length between early and late 1st gen trucks,) but pretty much everything else swapped over without trouble.
    I redid all the plow wiring with a new bank of relays and a DPST switch, so that one rocker switch changes over the headlights and energizes the plow solenoid/joystick circuit.
    I fabricated a tube bumper to hold the Meyer E-47 hydraulic unit, and fabricated a light bar tower. I sprayed both of those parts with UPOL Raptor bedliner and topcoated them with a good single-stage urethane to match the truck's gold two-tone paint. After that, I applied a generous coating of 3M Cavity Wax and Fluid Film on every surface of the truck's underside.
    Next couple posts should contain some photos... bear with me.
    Colin
  2. Mar 29, 2023 at 1:43 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Seller's original marketplace ad:
    The '99 a couple years before it was forced into retirement:
    On the way home, somewhere in Wyoming IIRC:
    Disassembly back in MN:
    Squirt, batacoma and J Williams like this.
  3. Mar 29, 2023 at 1:43 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Drivetrain out, minus the diffs:
    Reinforcement plates cut and welded to the frame:
    Big sloppy MIG action:
    All palletized and ready for the trip to the zinc bath:
    j-utah, CrustyTaco, essjay and 7 others like this.
  4. Mar 29, 2023 at 1:44 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Back from galvanizing. I had to chase every thread with a tap... still worth it.
    Crossmembers
    Once I hit 50 posts, someone can buy the complete manual trans swap from the 97:
    BassAckwards, Foot, j-utah and 13 others like this.
  5. Mar 29, 2023 at 1:44 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Gotta harvest the good parts... note the reverse cut vinyl on the windshield: "UNREGISTERED, UNINSURED, UNSAFE. DO NOT DRIVE THIS TRUCK OFF THE FARM." :bananadead:
    Easier to move around when you cut all the scrap metal off the back:
    Old frame sucked a big fatty:
    IMG_2962.jpg IMG_2965.jpg IMG_2971.jpg IMG_2973.jpg IMG_2974.jpg IMG_2975.jpg
    mjp2, essjay, davidstacoma and 9 others like this.
  6. Mar 29, 2023 at 1:48 PM
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
  7. Mar 29, 2023 at 1:53 PM
    J Williams
    J Williams Well-Known Member
    Jeff
    Central MN
    2021 TRD Pro
    Welcome to TW, Colin, from a fellow Minnesotan! Very familiar with the AZZ facility…former employer had a lot of parts galvanized there. Look forward to some more pics of your rig!
    ColinD[OP] likes this.
  8. Mar 29, 2023 at 2:05 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    New frame assembled; engine, trans, diffs, new springs, fuel tank, etc installed in the new frame.
    Cab Calloway or whatever
    Might fix that fender dinger and find a new flare one of these days. Doesn't bother me too much, it's a farm truck. Pro-tip for these bigger jobs: write your to-do list on the window with paint marker.
    Light tower built, still unpainted:
    Foot, mjp2, davidstacoma and 5 others like this.
  9. Mar 29, 2023 at 2:08 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Off to Tires Plus for its first lifetime alignment:
    I forgot to mention, between my acquisition of the rust-free '97 and beginning the swap, the engine in the '99 blew a head gasket and started consuming coolant. I actually pulled the engine and put it on the stand, replaced both head gaskets, and replaced the timing belt/idlers/tensioner etc and then put the engine back into the rusty truck just to get us through that plow season.... knowing full well I'd be pulling it all back apart the following summer. :rofl:
  10. Mar 29, 2023 at 2:08 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    TForan and Squirt like this.
  11. Mar 29, 2023 at 2:08 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    Upgraded the Meyer from those leaky ISO connectors to flat-face fittings.
    I loooooove gold!
  12. Mar 29, 2023 at 2:12 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Cool Tacoma!
    What's the story behind the F-650/750? with the flat bed and underlift?
  13. Mar 29, 2023 at 2:14 PM
    Nicklovin
    Nick
    Tacoless
    That's a sweet Ferd
  14. Mar 29, 2023 at 2:21 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    I have 10x as many photos of the Ford build as I do the Tacoma build. I don't know if this is quite the right place to post that.
    It started as a 26' Budget Rental moving van, which was flooded in Hurricane Sandy. I dragged it home from the Copart auction lot in Trenton, NJ and pretty much built it from the ground up into what it is today. The flatbed is all handmade from 10- and 12-gauge sheet, and also hot-dip galvanized. :D
    Colin
  15. Mar 29, 2023 at 2:31 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    IMG_1109.jpg 6B5FCCAF-667D-462E-AB96-20D297B241C2.jpg IMG_1599.jpg IMG_1367.jpg IMG_2495.jpg
  16. Mar 29, 2023 at 2:58 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    That last photo reminds me: I accidentally pressure-washed all the vinyl off the tailgate, so I found some good images online and traced the original fonts in Adobe Illustrator in order to create vector files. I don't really have any interest in selling stickers, especially now that everyone and their mother has a Cricut. I'll throw the files up in a Google Drive folder in case anyone wants to cut new graphics for themselves.
  17. Mar 29, 2023 at 3:07 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Sweet builds! This is definitely the right place to post what you've done.
    Welcome aboard:hattip:
  18. Mar 29, 2023 at 3:11 PM
    batacoma
    batacoma Truck Wars
    Cool, I see you did mention the Ford in your 1st post. I also like the King Ranch paint scheme on the Toyoya.
  19. Mar 29, 2023 at 3:11 PM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    Dang this is a cool thread! Welcome to TW!
  20. Mar 29, 2023 at 3:12 PM
    ColinD
    Minnesota
    97 Tacoma SR5 V6
    I don't know if you want me to start posting all my fabrication work... it might crash the server. :D
