97 New to me Baseline Maintenance Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by CA Freedive, Sep 24, 2011.
  1. Sep 24, 2011 at 12:38 AM
    CA Freedive
    CA Freedive [OP] Member
    Ben
    Enterprise, AL (Point Loma)
    1997 2.4L, 2wd, 5 spd, 88k, beige
    Seat covers.
    I recently bought a 1997 Tacoa w/ 88k 2wd, 5spd 2.4L Reg Cab for $4250 in SoCal, (it's always lived in SoCal and frame is perfect). It had a clean CarFax and a AAA Inspection at a local mechanic turned up only wear item replacement.
    I bought the Haynes manual and am going through and doing all of the routine services to "Baseline" the vehicle.
    So far:
    New Belts
    New Battery
    New front shocks
    Changed all oils w/ Mobil 1 Full Synth (Eng = 5w-30, Trans & Diff = 75w-90)
    To Do: (Input on things in this list is MUCH appreciated)
    lube chassis, dirveshaft, etc
    replace air filter if necessary
    replace spark plugs if necessary
    radiator drain and flush
    replace fuel filter
    replace O2 sensor
    replace hoses if necessary
    replace tires (mild tire rot)
    inspect steering components
    inspect exhaust
    inspect seat belt (where can I get a new seat belt assy, one is torn up?)
    inspect PCV valve
    inspect fuel system
    inspect brakes (new front rotors & pads & adjust parking brake)
    inspect clutch pedal
    inspect valve clearance
    inspect spark plug wires, distributor, rotor
    inspect & repack front wheel bearings (probably replace)
    inspect evaporative emission control sys
    inspect EGR valve
    So, my questions to you all would be is there anything that you would add or take away from this list and why?
    Is there any way to know if my more expensive sensors are still good? (for all I know they could be originals or replaced 20k miles ago)
    What can you tell me about inspecting and adjusting valve clearance? From reading over the Haynes Manual it doesn't seem terribly hard, just a little time consuming. I've read about people having to remove the camshaft to adjust the valves but Haynes doesn't mention this? Am I flirting with seriously screwing up my engine by doing this or am I fine so far as I follow directions and go slow?
    Also, how nice of a micrometer do I need to measure the shims if I need to adjust them?
    I was looking at the ranges of
    http://www.sears.com/shc/s/p_10153_12605_00940774000P?prdNo=1&blockNo=1&blockType=G1
    to
    http://www.amazon.com/Mitutoyo-103-...6?s=industrial&ie=UTF8&qid=1316849731&sr=1-16
    Will the cheap one be accurate enough or do I need the better one? Or do I need better than either one?
    Also does anyone have any experience with this valve adjusting tool? What are you using?
    http://www.amazon.com/Schley-SCH882...1?s=electronics&ie=UTF8&qid=1316846719&sr=1-1
    Thanks in advance for all of your help.
  2. Sep 24, 2011 at 9:42 PM
    CA Freedive
    Ben
    Seat covers.
  3. Sep 24, 2011 at 9:46 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Unless you're having engine trouble, don't mess with the valve clearances. Waste of time to fix something that ain't broke. Same goes for the wheel bearings, sure, pack em' wit grease, but why replace em' if they're fine? Take your truck in for an alignment check somewhere (free) and they will check the suspension before they do it. You can do this when you get new tires. Suspension to include ball joints, tie rods, and wheel bearings.
  4. Sep 24, 2011 at 9:48 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Inspect valve clearance is written in some Toyota maintenance booklets as "audible only". i.e. the mechanic listens to the engine and make adjustments only if the ticking sounds louder than usual.
    And O2 sensor should be replaced only when it fails (when you get the check engine light).
  5. Sep 24, 2011 at 10:51 PM
    scocar
    scocar hypotenoper
    To get the Toyota maintenance schedule specific to your year and model, go to toyotaownersonline.com and register (free). You need your VIN. You wil be able to get the owners manual, maint. sched., and possibly any dealer-performed maint. records and also recalls or TSBs.
    I don't think your engine needs regular valve adjustment. The 22RE 2.4 did every 15k miles.
  6. Sep 24, 2011 at 11:05 PM
    CA Freedive
    Ben
    Seat covers.
    Thanks very much, that saves me a lot of time and money!
  7. Sep 24, 2011 at 11:06 PM
    CA Freedive
    Ben
    Seat covers.
    Thanks, I've just been using the Haynes manual and it's not just for Tacomas so I'll check that out.
