'97 rear leaf question
Discussion in '1st Gen. Tacomas (1995-2004)' started by chaosrob, Nov 12, 2016.
  1. Nov 12, 2016 at 4:22 PM
    chaosrob
    chaosrob [OP] Well-Known Member
    I am sure this is probably a redundant question for you guys but search didn't give me what I am looking for.
    The right rear leaf spring is broken on my '97 Single Cab V-6 4x4. I purchased a set of stock replacement sprigs as I really do not want to lift this one (I am in process of building a 95.5 xtra cab and that one will get the joy). The frame on this truck was replaced by Mr T but apparently no love was given to any of the other components. When I went to remove the shackles I managed to get the nuts loose but I wound up having to cut the bolts to get them free, they were not budging otherwise, same with the ubolts.
    So for my long winded explanation above I have a very simple questions, do you recommend going back with MR T shackles and U Bolts or another supplier? I didn't see a lot of options out there for factory height. TIA
  2. Nov 12, 2016 at 4:48 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    I used ones from allprooffroad.com. They were extended a little but not too much if i remember. My main reason for this was they came with zerks so i could keep them from rusting in the future. Otherwise the best bet i believe was rockauto
  3. Nov 12, 2016 at 5:18 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    Stuck eye bolts is par for the course. Go with greaseable bolts with new bushings on the shackles. Replacing rusted u-bolts is a good idea too. I would have cut those off too if I knew how hard it was going to be the get them off.
  4. Nov 12, 2016 at 5:30 PM
    ghs57
    Chops
    Catskill Mts. NY
    Are you sure about this? Toyota did not replace frames on '95-'00 Tocomas under the extended warranty. Those model years were bought back by Toyota if the frame failed the rust inspection. I had both a '97 and a '00 bought back. Would have loved to have had new frames, as both were fairly low mileage trucks, but this was possible.
  5. Nov 12, 2016 at 6:54 PM
    chaosrob
    Thanks. Well I know the frame was replaced, not sure by who. The frame is almost completely rust free and the truck is from Minnesota and there is a parts sku on the frame in the front by drivers side wheel
  6. Nov 12, 2016 at 6:55 PM
    chaosrob
    Where, in your opinion, is the best place to purchase these parts
  7. Nov 13, 2016 at 7:30 PM
    ghs57
    Chops
    Catskill Mts. NY
    I got mine from wheeler's off-road. Go into the Tacoma section, and it's under suspension. Day star makes them, and they have their own brand. Other places may have them also, but that will give you the idea. You might also check Amazon or rock auto ( there is a discount code for rock auto in the vendor section).
  8. Nov 13, 2016 at 7:37 PM
    chaosrob
    I wound up just ordering some leafs from Napa and got factory u bolts/shackles, thanks guys
  9. Nov 13, 2016 at 7:54 PM
    ghs57
    Chops
    Catskill Mts. NY
    Just curious, what does Napa get for leafs? I assume they are equivalent to stock.
  10. Nov 13, 2016 at 7:56 PM
    chaosrob
    150.00 per side
  11. Nov 13, 2016 at 8:14 PM
    ghs57
    Chops
    Catskill Mts. NY
    That's significantly cheaper than OEM, and most of the replacement leafs. I hope they are as good.
    Good luck with the new parts.
  12. Nov 13, 2016 at 8:20 PM
    chaosrob
    Thank you, we shall see
  13. Nov 14, 2016 at 1:08 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Interesting my Napa does not sell springs or ubolts unless this is something new.
  14. Nov 14, 2016 at 5:05 AM
    chaosrob
    Odd. Took them one day to get the springs in, they didn't have specific u-bolts so I didn't get them there but they did have some that were 1/2' x 2.5" i.d. x 7 1/4 long, probably would have worked but I didn't want to have to cut the excess off the bottom as I wouldn't have had a socket long enough to tighten them :)
  15. Nov 14, 2016 at 1:43 PM
    chaosrob
    All done, slapped some Gabriel shocks on it while I was at it. The springs I got from Napa say Dorman on them if that helps?
    Not sure what the problem was
    Couldn't leave these on it since I was there
    Truck sits much better now
    I would like to put new springs on the front as well as shocks, again just stock height. I assume I would be better off going with the same brand shock in the front but what about springs? TIA
  16. Nov 14, 2016 at 4:17 PM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    wow that is some serious rust
  17. Nov 14, 2016 at 4:51 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Those look like some original shocks. You should sell them in the marketplace!
  18. Nov 14, 2016 at 5:21 PM
    chaosrob
    It has a new frame under it and the body is pretty rust free, I can deal with the little parts being rusty. It was a fun endeavor to say the least
  19. Nov 14, 2016 at 5:24 PM
    chaosrob
    I am sure they were the original shocks on this thing. They went in the trash where they belong :)
  20. Nov 14, 2016 at 5:26 PM
    chaosrob
    Looks much better in there now.
    99SuperTaco4x4 likes this.
