97 Tacoma 2.4 perfect ide stumbles at accelleration/no power/ no codes
Discussion in '1st Gen. Tacomas (1995-2004)' started by dishpro1, Jun 17, 2016.
  1. Jun 17, 2016 at 6:08 AM
    dishpro1
    dishpro1 [OP] New Member
    Hello all had this problem could not figure out why? I replaced air filter, fuel filter, checked the compression, sprayed carb cleaner all over engine, bottle sea foam 1/2 in gas 1/2 in oil (oil must be changed 500 miles after putting sea foam in oil) After all this problem remains, considered plugged cat, and finally someone posted an awesome video on youtube claiming he had fixed his car with identical symptoms. Mind you many people did mention possibly the MAF sensor nothing more. Check this out, The video shows the removal of the MAF sensor two little screws. Be careful taking off and putting back on. Upon inspecting the sensor i could see a so tiny layer of accumulated fine black dust. My immeadiate thought was ah this wont fix it, because such a tiny amount of debri was there. Spray the crap out of the tiny little wire with a resistor looking deal in the center with MAP sensor spray from NAPA let dry reassemble. My truck is fixed OH THANKS BE TO GOD ALL THIS GLORY IS YOURS FATHER!
  2. Jun 17, 2016 at 8:17 AM
    Bxnanaz
    Bxnanaz Well-Known Member
    2021 Tacoma TRDOR 6MT
    Nice! Good to see people posting how they fixed their problem. I'm sure this will help someone one day
  3. Jun 17, 2016 at 3:37 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    My 96 2.4 had the same issues, but finally set a code for too rich. I sprayed the maf off and reinstalled. Once you reach the too rich code you will need to disconnect the battery to reset the fuel tables. If you don't you will have to wait for them to trim themselves.
