97 tacoma 4x4 partout
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Tour991, Dec 4, 2016.
  1. Jan 14, 2017 at 6:37 PM
    Tour991
    Tour991 [OP] Supplier of used parts
    James
    Zephyr Cove NV Lake Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited
    I'll check through my parts tomorrow morning see if I have it
  2. Jan 14, 2017 at 6:38 PM
    Tour991
    James
    I have it but I'm not sure if it's the same.
  3. Jan 14, 2017 at 6:39 PM
    Tour991
    James
    I have the tilt ignition switch pasenger door and gas door but no driver door or key
  4. Jan 14, 2017 at 6:40 PM
    Tour991
    James
    I'll check tomorrow and let,you know
  5. Jan 14, 2017 at 6:43 PM
    Tour991
    James
  6. Jan 14, 2017 at 6:46 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I only want the rears.
    How much and shipping will be 82801
  7. Jan 14, 2017 at 9:13 PM
    Croth51
    Croth51 Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    Post a pic?
  8. Jan 16, 2017 at 8:38 PM
    adrenal321
    adrenal321 Member
    Edgar
    Los Angeles County
    95.5 Tacoma 4x4
    None all stock
    how about the spindle and the hubs?
  9. Jan 16, 2017 at 8:43 PM
    Tour991
    James
    Sorry they are gone
  10. Jan 16, 2017 at 8:44 PM
    adrenal321
    adrenal321 Member
    Edgar
    Los Angeles County
    95.5 Tacoma 4x4
    None all stock
    ok thANKS
  11. Jan 17, 2017 at 1:40 AM
    Scarecrow4420
    Scarecrow4420 Pay no mind to the rabble
    Weston
    Colorado
    02 SAS supercharged Dbl cab Tacoma
    Ford HP 44 with radius arms up front, 4.56 gears, Dana 60 in the rear 3linked on coils, supercharger with URD 7th injector kit, 5 spd swap
    How much for the shifter shaft?
  12. Jan 17, 2017 at 6:34 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    Do you have the inner front wheel well skirts/aprons that go above the frame & wheel wells( both sides) to seal off the engine ? If so,How much , shipped to 47802? thanks
  13. Jan 17, 2017 at 7:25 AM
    Tour991
    James
    keeping the shifter
  14. Jan 18, 2017 at 5:10 PM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
    How much for the 2 brake lines that come off the master cylinder they both coil then go down to a T on the frame . Also on the dehydrator on the front of the truck the tube on top of it that is L shaped.
  15. Jan 20, 2017 at 10:09 PM
    #35
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I'm looking for one of the knobs for the AC/heater control and one of those square knob things that go on the end of the sliding levers.
  16. Jan 21, 2017 at 7:27 AM
    #36
    Benz83
    Benz83 Hybird Tacoma
    Ben Soto
    Bakersfield, CA
    96 Tacoma 3RZ Manual 4x4
    Pacer Header. K&N Air Filter. Upgraded Stainless Steel Braided Brake & Clutch Lines from LCE. Bullet Proof Motor Mounts from LCE. Upgraded Shock by KYB - Mono Max. EGR Delete Kit from LCE. Throttle Body Spacer from LCE. Ported Cylinder Head and Intake Manifold. Teflon Intake and Throttle Body Gaskets from LCE. Custom Prerunner Bumper with LED Light Bar. Custom Traction Bars.
    Do you have the stereo dash cover with the cup holder?
  17. Jan 21, 2017 at 11:33 AM
    #37
    Tour991
    James
    i do have the slide end. but no ac knobs this is what mine look like.download.jpg
  18. Jan 21, 2017 at 11:33 AM
    #38
    Tour991
    James
    no sorry already sold
  19. Jan 21, 2017 at 11:39 AM
    #39
    boostedka
    James
    NM
    Cool. I forgot that the 95-97 had all sliders. I just need one or two of those little ends. eBay wants like $11 for 4 of them so trying to find them for a little less. IDK if you're willing to sell just those since you have the whole unit still. What do you think? Just LMK. If not I can buy the ones on eBay if you don't want to split it up
    #39
  20. Jan 21, 2017 at 11:41 AM
    #40
    Benz83
    Ben Soto
    Bakersfield, CA
    I looking stereo dash cover with cup holder without the climate control.Screenshot_2017-01-21-11-36-50.jpg
