97 Tacoma a/c problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by ammobelt, Jun 21, 2013.
  1. Jun 21, 2013 at 12:28 PM
    ammobelt
    ammobelt [OP] Member
    1997 tacoma
    had this truck for just over a year now and all of a sudden the light doesn't lite up on the a/c switch and the compressor isn't kicking in..i assume there is a clutch kick in for the compressor somewhere or maybe a fuse.. any suggestions for troubleshooting this problem?thanks..
  2. Jun 21, 2013 at 12:31 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Have you checked the switch? Fuse first-then switch.
    Had a switch go bad on my 91.
  3. Jun 21, 2013 at 4:10 PM
    ammobelt
    1997 tacoma
    take the switch out and put the two[I guess] wires together to see if compressor kicks in?
  4. Jun 21, 2013 at 6:11 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    You might just be low on 'freon' (R134 that is). There is a sensor that prevents the compressor from coming on when it detects not enough freon. It saves the compressor from burning up.
    Check the 10-amp A/C fuse first, though.
  5. Jun 22, 2013 at 12:49 PM
    ammobelt
    1997 tacoma
    feel like an idiot..it was just the fuse..i posted my problem in case it wasn't a fuse and I had more things to go on..thanks guys..
  6. Jun 22, 2013 at 2:41 PM
    ammobelt
    1997 tacoma
    oops..spoke too soon..fuses blow instantly...could be anything...sigh..
  7. Jun 22, 2013 at 3:41 PM
    SDSam
    SDSam from Dirt bike to Dezert Couch
    San Diego
    00 Tacoma prerunner
    Icon Shocks, BTF front, Deaver f67, 33's on stocks, Fiberwerxs 1pc, TDR S/C, Bed & Eng Caged
    Compressor clutch would be where to start testing amp draw or shorting itself.
  8. Jun 22, 2013 at 4:04 PM
    jvswaim
    jvswaim Well-Known Member
    Joe
    Oklahoma
    96 LX 2WD
    225/70 x 14 tires
    Don't want to be discouraging, but a yr ago this happened to me and in the end, the whole A/C system ended up having to be replaced. But it did have 250K miles on it.
  9. Jun 22, 2013 at 5:08 PM
    ammobelt
    1997 tacoma
    ok..i'll have the clutch looked at..there's a black powder residue on the engine block next to a/c unit..thanks..
  10. Jun 23, 2013 at 6:19 PM
    tan4x4
    Rick
    Folsom, CA
    When, exactly, does the fuse blow?
    As soon as you insert the new fuse?
    When you turn the key to ACC?
    When you turn the key to IGN?
    When you start the truck?
    When you push the A/C button after all the above?
    This would help narrow it down. First stock up on 10-amp fuses.
    Also, one way to eliminate the clutch as a problem, is to disconnect the connector on top of the compressor, then try the test. If the fuse does not blow, then you know its the compressor clutch (not the compressor itself).
    I have replaced the clutch on my '84 4Runner. It was do-able. The FSM had the detailed instructions. I didn't need a special tool other than snap-ring pliers. Not sure if the Tacoma clutch is replace-able.
  11. Jun 24, 2013 at 11:37 AM
    ammobelt
    1997 tacoma
    I put the new fuse in,crank up the engine,put blower on lowest setting and hit a/c switch..i disconnected wire to clutch,put in new fuse and fuse held..clutch I guess ....
  12. Jun 24, 2013 at 2:08 PM
    SDSam
    San Diego
    00 Tacoma prerunner
    with the engine off turn the compressor center only by hand and see how it feels, should rotate smooth and only feel the load of it compressing
  13. Jun 24, 2013 at 8:50 PM
    ammobelt
    1997 tacoma
  14. Jun 25, 2013 at 12:32 PM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    Sounds like a bad clutch coil to me. They are replaceable with the compressor on just pull the belt. And use a strap wrench or an oil filter wrench to hold the clutch while loosening the center bolt. Be careful b/c the shims will fall out when you take the clutch off the front. Don't lose them. You'll probably need snap ring pliers to pull the coil off. Good luck.
  15. Jun 26, 2013 at 10:10 AM
    tan4x4
    Rick
    Folsom, CA
    If you are going to try to replace the clutch, a possible short cut would be to LOOSEN the center bolt on the clutch/compressor while still on the truck with the belt still on and tight. This might work better than the method normally used, and suggested by Fordless. I think there is room.
  16. Jun 26, 2013 at 10:24 AM
    Fordless
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    You would have to jump 12v to the clutch to engage it or the hub will spin independently of the belt.
  17. Jun 26, 2013 at 10:49 AM
    SDSam
    San Diego
    00 Tacoma prerunner
  18. Jun 27, 2013 at 11:17 AM
    ammobelt
    1997 tacoma
    ok..hoped it was bad clutch.. found clutch only as most want to sell you new compressor with it..had my guy that works on my truck take off the old one and put on new one without taking compressor off..works like a champ so far..thanks for all the great comments and help..
  19. Jun 27, 2013 at 1:01 PM
    tan4x4
    Rick
    Folsom, CA
    Doohh !! Thanx for correcting me. Must have been thinking of the PS pump.
  20. Jun 27, 2013 at 1:48 PM
    ammobelt
    1997 tacoma
