97 Tacoma ac not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by Troybrah94, Feb 22, 2019.
  1. Feb 22, 2019 at 6:32 PM
    Troybrah94
    Troybrah94 [OP] Member
    Troy
    1997 Tan Tacoma Base 2WD
    Radio
    AC stopped working. Refrigerant is reading fine. Stopped rather abruptly from what I remember(been a while since I used it temperatures cooled down) but I'm pretty pretty sure that it stopped working almost right after I installed my radio or fixed my car lighter that stopped working. Both of those happened right around the same time, and I think that's when the ac stopped. Since then I have jumped the clutch and it spins when I do and checked the refrigerant and that read fine. Fuse is fine as well. Thank you in advance.
  2. Feb 22, 2019 at 6:40 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Maybe the ground?
  3. Feb 22, 2019 at 7:47 PM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    So, you are saying the clutch is not engaging when you press the AC button? If you were doing work under the dash, I would be looking at the the A/C button and wiring.
  4. Feb 22, 2019 at 7:47 PM
    Glamisman
    Glamisman Well-Known Member
    does the AC light illuminate when pushed?
  5. Feb 22, 2019 at 8:38 PM
    Troybrah94
    Troy
    Radio
    Yes, it lights up when pushed and i can check again, but I couldn't really see where in that area I could have messed up much. I thought that had to be it at one point, but i couldn't really see anything that would make a difference near where i was.
  6. Feb 22, 2019 at 8:48 PM
    Glamisman
    check for voltage at the disconnect for the AC compressor clutch.
  7. Feb 22, 2019 at 8:50 PM
    Troybrah94
    Troy
    Radio
    Thank you. That was my next move for tomorrow when the sun's out. Because I want to figure this out soon before it starts getting hotter. In Florida and already to the mid 80s with high humidity as always.
  8. Feb 22, 2019 at 9:07 PM
    Glamisman
    check for voltage at both sides of the dual pressure switch too.
