97 Tacoma AT 4x4 with hub locks not working
Discussion in '1st Gen. Tacomas (1995-2004)' started by nachoaveragetaco, Nov 2, 2015.
  1. Nov 2, 2015 at 10:52 AM
    nachoaveragetaco
    nachoaveragetaco [OP] New Member
    Jack
    Anchorage, AK
    1997 Tacoma AT 4x4 manual hub lock top shift chain case
    Hi everyone, been using this site for awhile but had a few questions so finely made an account.
    Problem
    1997 AT tacoma 4x4 with locking hubs has lost 4HI and 4LO.
    I have checked both hubs and they lock and turn FDS when spun.
    TC is top shift chain drive. (3RZ-FE A/T)
    does anyone have any experience getting into the case without dropping the tranny?
    I'm going to drain the oil tonight and check for metal and see if the chain looks ok. also pull the shift and see if the fork locks.
  2. Nov 2, 2015 at 1:52 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I'm no expert with TC's, but I have replaced a gear-driven one in a hi-lux.
    What are your exact symptoms?
    Is it possible that the front diff pinion might be stripped?
    Have you verified that, with the hubs in 'free-wheel' and TC in 4WD, the front DS does not spin?
  3. Nov 2, 2015 at 3:58 PM
    nachoaveragetaco
    Jack
    Anchorage, AK
    thanks for replying :D
    hubs unlocked, 4wd HI and LO, wheels spin without any movement of FDS.
    hubs locked in, both 4wd, FDS moves free and spins front tires. (thats not right im guessing)
    first thing i checked was the hubs...
    im thinking it has to be something in the TC.
    ive come across two real old posts (5 years plus https://www.tacomaworld.com/members/chewmanfoo.37412/) where it was a broken fork pressure pin, which im really hoping for at this point, considering it could be a snapped chain, stripped sleeve/sprocket, broken shift fork, or really anything else in that damn box.
    the guy (chewmanfoo) mentioned accessing the TC from the rear and finding the broken pin, but i couldnt determine if he had to drop the whole tranny to make some wiggle room.
    im wondering if its possible to disconnect the rear DS and pop the case open without all that.
    thanks again,
    Jack
