97 Tacoma clutch?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Toyota Dave, Oct 15, 2010.
  1. Oct 15, 2010 at 6:16 AM
    Toyota Dave
    Toyota Dave [OP] Active Member
    Dave
    About how many miles will a clutch last? I've got 115k on mine and have noticed a churping sound from it, it goes away when you push the clutch in alittle and you can hear the churping sound when there is no load on the motor.
  2. Oct 15, 2010 at 6:49 AM
    tacosuprem
    tacosuprem Well-Known Member
    Florida
    4x4
    what motor? I have a 97 2.7 with 211k miles with stock clutch. They can last if your easy on the truck.
  3. Oct 15, 2010 at 7:12 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    I sold my 96 with 205k on the original clutch, I put ~140k on the truck
  4. Oct 15, 2010 at 7:21 AM
    WASTE MANAGEMENT
    WASTE MANAGEMENT Well-Known Member
    Travis
    Umatilla Florida
    97 tacoma 4x4 3.4 w/5 speed
    new 31x10.5 tires, mag wheels, drilled rotors, new sound, and a cb.
    My 97 is 4x4 with a 3.4 and I have been ruff on it a few times. My clutch went out at 158,000. I think the churping sound is the throw out bearing, my new one does it. I used a cheep clutch from a local parts store. I want to change it again with a centerforce clutch I have heard good things about them.
  5. Oct 15, 2010 at 7:32 AM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    my 97 2.7 lasted till about 148k I guess the owners before me were non-drivers???
    Sounds like you throwout bearing is going bad.
  6. Oct 15, 2010 at 9:48 AM
    Toyota Dave
    Dave
    It's the 3.4V6 I've been easy on the truck it just started doing it and seems to go away on warm days don't know what difference that would make.
  7. Oct 15, 2010 at 10:46 AM
    Toyota Dave
    Dave
    After messing with it more if I push the clutch in maybe a 1/2 inch the churping stops. Is there something that could be loose?
  8. Oct 15, 2010 at 5:48 PM
    Avsguy33
    Avsguy33 Well-Known Member
    I have the same problem with mine currently. I think its the TOB. Same symptoms, clutch barely in it goes away, all the way out it chirps.
    I drive my truck pretty hard so I know its coming. Just need to find the time to swap it all out.
  9. Oct 15, 2010 at 5:53 PM
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Sounds like the noise you're getting could be related to the release bearing making contact with the pressure plate fingers while the clutch is disengaged.
    Possible causes would include: Bent fork. Bent fingers. Misalignment. Warped pressue plate. Maybe a faulty slave cylinder. Bad bearing. Retainer might need a little lube.
  10. Oct 16, 2010 at 7:00 AM
    WASTE MANAGEMENT
    Travis
    Umatilla Florida
    Yep mine is the same way, once you put a load on the throw out bearing it quits. Time to throw it out...
  11. Oct 26, 2010 at 6:30 AM
    Toyota Dave
    Dave
    How much will it cost to get it fixed? Or should I just let it go untill it breaks....I blame the city driving I have to do to get to work.
    I've taken care of my truck it shouldn't be going out at 115k should it?
  12. Oct 26, 2010 at 6:44 AM
    TacomaJack09
    Jackson
    Montana!
    06 Access Cab 4x4
    I was quoted around $600 - $700 to replace it.
    That's when I decided to do it myself. Its not terribly hard, just need two people and the correct tools. It cost me about $230 for new clutch and I decided to buy a new flywheel too.
  13. Oct 26, 2010 at 7:10 AM
    Toyota Dave
    Dave
    unfortunately im not a mechanic though. I wonder how long it would last as is.
    The clutch seems to work fine expect that annoying cricket sound.
    I don't understand why pressing the clutch in only a 1/2 inch would make the sound stop, I'm not pressing it in far anough to engage the clutch if anything mine has alot of free play in it.
  14. Oct 28, 2010 at 4:41 AM
    offroadTRD
    offroadTRD Well-Known Member
    Dinwiddie County, Virginia
    2000 Tacoma V6 SR5 4x4 TRD- Fabtech
    Fabtech 3" adjustable coil-over system, Alcan 8-leaf spring pack, Fabtech 3" body lift.
    It's your release/throwout bearing......don't worry about it, trust me. I push my clutch pedal in half an inch and the noise goes away also. I replaced my clutch out/release bearing at 150,000 and mine still does it. Don't worry about it until the clutch finally slips on you. You will know when it happens, but until it does, DRIVE DRIVE DRIVE. Its okay and it's not going to hurt anything.
