'97 Tacoma compression issues
Discussion in '4 Cylinder' started by trtripoli, Jan 21, 2010.
  1. Jan 21, 2010 at 2:37 PM
    trtripoli
    trtripoli [OP] lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    I've got a friend with a '97 4 cylinder Tacoma. She's been having compression issue's I guess (according to the dealer). The dealer said it's most likely (80%) a valve that needs to be replace, and they quoted her $2200.
    First, is this amount reasonable? How much should something like this cost to fix?
    Second, if it is indeed a valve that needs to be replaced, is something I could do (average mechanical ability, but quick learner)?
    Any input here would be appreciated, shes located in the Boulder, CO area. Thanks
  2. Jan 22, 2010 at 7:21 PM
    VLANDER005
    VLANDER005 Well-Known Member
    96 YODA, 2.7 I4, 31" MTR's
    31" Goodyear MTR's
    I know I have seen entire rebuilt cylinder heads for around 600 dollars. So 2200 is certainly quite high in my opinion. 55 dollars for a new head gasket. 75 for head bolts if yours can't be reused and about 8-12 hours of your time. I just replaced my head gasket on my 96 tacoma 2.7 and it really wasn't that bad. Just take your time, mark the distributor position correctly, locate TDC before you do anything and organize your cam bearings when you take them off. It really wasn't too bad.
  3. Jan 25, 2010 at 5:25 PM
    97taco111
    97taco111 New Member
    lake luzerne, new york
    97 tacoma lx
    smitty built nerf bars, extang touneu cover, tires,k&n filters
    you could prolly put in a new motor for 2200
