97 tacoma hard to start at running temp on warm days
Discussion in '1st Gen. Tacomas (1995-2004)' started by MamaCheeka, Apr 15, 2013.
  1. Apr 15, 2013 at 6:24 AM
    MamaCheeka
    MamaCheeka [OP] Member
    southeastern PA
    2007 Tacoma
    I've been following the feeds on this issue and so far, i have had no luck finding a solution.
    I have a 97 3.4 4wd tacoma.
    Does not over heat. Does not throw code. Starts fine when cold. starts fine in winter when at running temp.
    DOES NOT want to start when at running temp on warm days.
    I have replaced MAF, Throttle body sensor, crank shaft sensor, plug wires, plugs, and 1 of 3 coil packs.
    I am now curious if there is a heat soaking issue. I have run a volt check on the starter and its clear....
    REALLY NEED AND WOULD APPRECIATE ANY AND ALL CONGESTIONS!!
  2. Apr 15, 2013 at 7:11 AM
    brs127s
    brs127s Well-Known Member
    O'Fallon, MO
    04 D-Cab 4x4 Limited TRD
    TRD Headers, Aero Turbine AT2525XL Deckplate Mod, TRD tranny cooler, King Coilovers, LR UCAs, Alcan 5 Leaf springs and Bilstein 5100s, Shrockworks front bumper, CBI rear bumper.
    I had this same thing happen on my 94 Toyota. It may be one of two things. The cold-start sensor, or the cold start injector. I can't remember the actual name of the sensor/injector. The sensor senses the temp of the engine. When cold, it sends additional gas to the motor via the cold start injector for starting...kind of like a choke.
    More than likely one of the two are bad. My 94 would start perfectly when it was cold, but once it was warm, it would act like it was flooded. It would eventually start, but either after alot of cranking or after sitting for about 15 minutes. I could usually roll start it if I was on enough of a slope and didn't crank it at all.
  3. Apr 15, 2013 at 7:14 AM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    I will definitely check that out!!!
    appreciate your input!!! :)
  4. Apr 16, 2013 at 12:06 PM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    Is it cranking fine but just not starting? Or is it having trouble cranking?
  5. Apr 16, 2013 at 12:26 PM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    cranks fine, just wont start
  6. Apr 16, 2013 at 5:00 PM
    Gooch
    Orange County CA
    Copy.
    I had a similar problem and it was a dirty MAF. But I see you've already been there/done that.
  7. Apr 16, 2013 at 8:14 PM
    CUtacomaTIGER
    CUtacomaTIGER Unprofessional Driver
    Clemson
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Window Rain Guards Bed Liner Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges
    i'd say check the engine coolant temperature sensor. not exactly the same conditions as me when my ect went bad, but similar enough that it's something to look into if you're out of ideas for now
