97 tacoma hard to start on warm days at running temp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MamaCheeka, Apr 15, 2013.
  1. Apr 15, 2013 at 6:06 AM
    MamaCheeka
    MamaCheeka [OP] Member
    southeastern PA
    2007 Tacoma
    i have been reading threads and taking all suggestions and nothing has prevailed to be the all mighty fix! i have replaced throttle body sensor, MAF sensor, crank shaft sensor, 1 of 3 coil packs, new wires...at my wits end.
    Its not throwing any codes!!
    HELP!!!!
  2. Apr 15, 2013 at 6:16 AM
    BamaToy1997
    Bill
    Navarre, FL
    Lots of things can cause this. A scan tool that can give you live data, and a fuel pressure gauge would be a great help to you. Have you done all of the regular maintenance, including replacing the fuel filter? I noticed you mentioned new wires. How about plugs?
  3. Apr 15, 2013 at 6:30 AM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    replaced wires, plugs, fuel filter, fuel pump @1 yr ago, thermostat...
  4. Apr 15, 2013 at 6:40 AM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    Throttle body sensor? You mean TPS? That shouldn't have much to do with your issue.
    I'd check the coolant temp sensor.
  5. Apr 15, 2013 at 6:52 AM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    coolant temp sensor? would this is a possibility even if the truck isnt overheating?
    I've read on a forum this morning about the air flow sensor...located inside the air filter casing....your thoughts?
    also...whats your thoughts on a heat soaking issue with the starter...something simple being its not throwing a code, but hidden enough to be a pain in my butt! if this would be the case, what are the possible heat sources? i dont hear an exhaust leak...i read somewhere they recommended a heat wrap for the starter?
  6. Apr 15, 2013 at 7:20 AM
    TherealScuba
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    The IAT (intake air temp sensor) could be going bad, too.
    The CTS tells the computer whether or not the truck is cold or hot, and that would cause bad warm starting while cold starting is just fine.
    You need to check the FSM and start checking those sensors.
    Guessing isn't going to do much.
  7. Apr 15, 2013 at 7:32 AM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    agreed..guessing is running me broke and leaving me frustrated.
  8. Apr 15, 2013 at 9:42 AM
    BamaToy1997
    Bill
    Navarre, FL
    OK, hang on a second. Let's make sure we are looking at the correct problem. There is a difference between a engine not CRANKING, and an engine not STARTING. Your question about hot soaking causing an issue with the starter has prompted this question.
    Does the engine turn over normally, but won't start after a hot soak, or does it not crank at all?
    A bit vague on the understanding of your complaint at this point. Cranks won't start, or won't crank at all?
  9. Apr 15, 2013 at 9:46 AM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    starter turns..but engine wont fire up. well correction, it will start...eventually, but then backfires, almost like its flooded.
  10. Apr 15, 2013 at 9:48 AM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    ..and yes, when its cold, it fires right up, without hesitation. in the winter it will start right up, even when at running temp.
    but when its warm and at running temp, it'll acts like its flooded when starting
  11. Apr 15, 2013 at 10:39 AM
    BamaToy1997
    Bill
    Navarre, FL
    OK, thank you. I was just wanting to be sure. A hot soaked batter would not be the issue then if it still turns over at normal speed. So you can eliminate that as an issue.
    A malfunctioning coolant temp sensor COULD cause an issue like this, but I am not 100% sure this is your fault. I will have to look some things up.
    I would be a LITTLE suspicious of a bad fuel pump. Have you noticed this ocuring all the time, or perhaps only when you are at 1/4 tank or less, on a hot/warm day?
  12. Apr 15, 2013 at 10:57 AM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    I would greatly appreciate you taking time to research this issue and attempt to help me!!!!
  13. Apr 15, 2013 at 10:59 AM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    fuel level doesnt affect it. yesterday, after i replaced the crank sensor, i had 3/4 of a tank and after i got it to running temp, turned it off, let it sit for 15 min, i had the same issue
  14. Apr 15, 2013 at 4:00 PM
    BamaToy1997
    Bill
    Navarre, FL
    I hate to say it, but at this point I think your money would best be served by getting someone with a scan tool to take a look at it. Any of a number of sensors could be failing after getting hot, the fuel pump could be failing after getting hot (Even though the fuel pump is in the tank, it is not uncommon for them to get hot, and fail), the ECM could be getting hot (Though I doubt it is the cause, it is not unheard of) my diagnostic information shows too many for making a guess. You really need a professional to look at it. I would be happy to, but I don't think you want to take a road trip to Alabama. lol.
  15. Apr 16, 2013 at 3:33 AM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    although a trip to Bama would be awesome, i dont think that is feasible at this point lol but i do thank you for your input and greatly appreciate your time and efforts in helping me. I will definitely post the fix..whenever I locate it!!
  16. Apr 16, 2013 at 7:35 AM
    BamaToy1997
    Bill
    Navarre, FL
    Well don't abandon all hope with us yet! Once you get more information we may be able to help you with finding a low-cost fix or alternatives. Let us know what you find out!
  17. Apr 16, 2013 at 8:41 AM
    MamaCheeka
    southeastern PA
    2007 Tacoma
    oh i NEVER give up hope...once hope is gone, all is lost!! lol
    i will definitely post anything i discover during this process --- on the plus side, i'm learning a ton about yota's, nothin wrong with that!!! lol
    Thanks again for all your help, truly appreciate it!!!
