'97 Tacoma Headlight Replacement Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by greenmonk, Mar 9, 2012.
  1. Mar 9, 2012 at 11:50 AM
    greenmonk
    greenmonk [OP] Member
    Northern VA
    1997 Tacoma Xcab V6
    I have a question for you guys. I need to replace my headlights for my 1997 Tacoma 2wd V6. I talked to my mechanic who called around to find out the price of OEM headlights. He said after a bunch of calls, he finally found them through NAPA for about $150 each. That seems kind of high to me for a headlight assembly with a plastic front. He said I could also buy my own headlights and he would install them.
    My question is this, are there any headlights that will last a long time like my original headlights that aren't as expensive? Or are there other headlights that I should be looking at other than the OEM's?
    If I'm going to have to spend that much on a headlight assembly, I'd like it to at least be a good and reliable headlight. He said I could upgrade to halogens (?), but it would cost about $300 more in labor to do the conversion (if I understood what he was saying).
    Can someone help me so I can get the best headlight without breaking my bank? Being able to see stuff at night is very important to me. Right now, I can barely see in front of me. Thanks!
  2. Mar 9, 2012 at 1:40 PM
    Dhawk1313
    Dhawk1313 Well-Known Member
    Drew
    New Jersey
    99 SR5
    Clear Corners, Clear Turn Signals, Pioneer Headunit, Kenwood speakers up front, Alpines in back, Billy 5100's front + rear, Toytec AAL, Eibach/Toytec Coilovers, Toytec Diff drop, Smoked taillights
  3. Mar 9, 2012 at 3:08 PM
    TacomaV6
    TacomaV6 Well-Known Member
    Bay Area
    1997 Tacoma 2WD v6
    Brush Guard Hid lighting Custom Prelude Fogs
    x2
  4. Mar 9, 2012 at 5:59 PM
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    www.roundeyes.com
    best replacements, replaces the sealed beam to a conventional beam.
    1000x better light and you can replace just the bulbs.
  5. Mar 9, 2012 at 6:02 PM
    Boilermaker99
    Boilermaker99 555
    Andrew
    Atlantic beach
    1999 SR5 TRD 4x4 3.4 V6
    ARE cap, Rhino lined bed, Custom Advantage-Max seat covers, Kenwood stereo and speakers, Debadged all emblems, blackedout grill, Off road lights, engine bay LEDs, Uniden Cb, Bedlined rockers and rims, Custom front and rear bumper, Hilo jack and mounts, Yakima load warrior, Magnaflow 14" muffler, Intake/prefilter, rebuilt frontend after accident so sort of frankensteined!!
    On a 97 just buy the ebay aftermarkets for 60 bucks. If you need to replace them you can do it 5 times before your in the hole for the price of the one set of OEMs.
  6. Mar 9, 2012 at 6:03 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    I know that those lights fit 1997 trucks, but I think the OP meant 1998-2000 :notsure:
  7. Mar 9, 2012 at 6:05 PM
    Boilermaker99
    Boilermaker99 555
    Andrew
    Atlantic beach
    Says on her profile she owns a 97?
  8. Mar 9, 2012 at 6:23 PM
    mizzac
    Mac
    Montana/CO
    Yota-less
    Stickers
    Ive noticed on alot of websites, it says the headlights are for 97-00 but they definatelyu wont fit a 97.
  9. Mar 9, 2012 at 6:31 PM
    TACOMABOSS
    96 SR5 4x4
    yeah, the body styles were 95.5-97, 98-00, 01-04
  10. Mar 9, 2012 at 6:32 PM
    TACOMABOSS
    96 SR5 4x4
    If she does in fact own a 97, the first few lights that were posted will not work. The ones mizzac posted will
  11. Mar 9, 2012 at 6:33 PM
    greenmonk
    Northern VA
    1997 Tacoma Xcab V6
    It's definitely a 1997 and a 2wd. Had it since it's first miles on the odometer. It's only at 150k now. Still using the original lights. Hardly any light passes through them now. I need new lights or I won't pass VA inspections this year. I've been warned the last two years by the inspector that they're getting worse and probably won't pass this year.
    I'll definitely look at Ebay and see what there is. My only problem with getting the cheap ones is that I don't know how to replace lights, so if they don't last I'll have to pay someone to replace them for me. That really will eat into my savings from getting the cheaper ones. Does that make sense?
    Also, my headlights are the plastic ones where I can replace the bulb. They aren't like the 4x4 version if I'm not mistaking. They are different, right? Or is it the model years that are different?
    I just want something that gives me good light output. It's really dark where I live. Thanks for your replies. Any other suggestions or thoughts?
  12. Mar 9, 2012 at 6:37 PM
    TACOMABOSS
    96 SR5 4x4
    Not 100% sure because yours is 2wd, but my 4wd(same body style as yours) is a sealed unit. the lights them selves cannot be replaced. The ones mizzac posted are what I want to get
  13. Mar 9, 2012 at 6:41 PM
    ruler1
    ruler1 stump thumper
    palmetto fl
    97 2.7 4x4 5speed
    header, k&n intake, ome coils, springs and struts,diff drop, Urd simulator, dynomax exhaust, slotted roters, bpv relocater
    97 is a strange year for the headlights. I have also had good luck with eBay headlights. Spend some time reading feedback reviews and you will be fine. I went with a stock smoked (lightly tinted) headlight on the car and they were awesome. Night and day compared to old ones.
  14. Mar 9, 2012 at 6:43 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    The headlights on the 95.5-97 were all standard 7X9 glass sealed headlight. You could get the aftermarket with the replaceable bulb. I buy my headlights for $19.95 a piece at a auto store. The part# is H6054 and they fit on many different vehicle makes and models.
    If you want to go aftermarket, and it sounds like you already have the after market headlight unit, then just replace the bulb inside and restore the plastic lens with a light restore kit.
    EDIT: The 2wd models came with the same headlight as the 98-00 Tacoma. Non-sealed headlight with replaceable bulb. I would just restore the lens and replace the bulb.
  15. Mar 9, 2012 at 6:47 PM
    ruler1
    palmetto fl
    97 2.7 4x4 5speed
    The 2wd headlights are different on 97. That is the first year of the switch. Only the 2wd 97's though.
  16. Mar 9, 2012 at 6:49 PM
    TACOMABOSS
    96 SR5 4x4
    I never knew that. Thats interesting. OP disreguard my last few posts.
  17. Mar 9, 2012 at 6:55 PM
    MapleMoose
    Ian
    West Kootenays
    1996 Tacoma SR5
    "EDIT: The 2wd models came with the same headlight as the 98-00 Tacoma. Non-sealed headlight with replaceable bulb. I would just restore the lens and replace the bulb."
  18. Mar 9, 2012 at 6:56 PM
    Boilermaker99
    Boilermaker99 555
    Andrew
    Atlantic beach
    You just live up the road, if you need help replacing come to hoodbridge and I will swap them for you. No charge hombre!!
  19. Mar 9, 2012 at 6:58 PM
    greenmonk
    Northern VA
    1997 Tacoma Xcab V6
    To restore the headlight, it would have to be wet sanded, right? I've used the restoration stuff that comes in a small bottle to try and buff it out for the last two years to get through VA inspections, but the guy told me it wouldn't work for another year. It was that discolored, so not enough light was passing through.
    And both headlights let me change the bulb because I changed both bulbs maybe 6 months ago when one of the lights went out. Maybe it's a 2wd thing because I've replaced the bulbs at least a couple times since I've owned it. I know they aren't aftermarket because I've owned the Tacoma since the beginning. I can't imagine the dealer would change out the brand new lights before selling it to me. :notsure:
    EDIT: I see you guys beat me to posting and someone confirmed that the 2wd models allow you to change out the bulbs.
  20. Mar 9, 2012 at 7:02 PM
    ruler1
    palmetto fl
    97 2.7 4x4 5speed
    Yea I saw you changed it while I was posting.
    I would still say an eBay unit though. You can only do so much to a 15 year old headlight housing.
