97 Tacoma injector upgrade
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma1997$, Aug 18, 2025.
  1. Aug 19, 2025 at 2:14 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    There was a post recently (not sure how recently) where the OP found injectors common to other toyotas and had them all listed out... IIRC it was like a high lander or the lexus equivalent...
    t0p_d0g likes this.
  2. Aug 19, 2025 at 6:31 PM
    Black97v6MT
    Black97v6MT 366k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Well technically it was just harmonic balancer puck of metal that launched
    But it's all one piece :(
  3. Aug 20, 2025 at 8:29 AM
    rish57
    rish57 Well-Known Member
    2000 Tacoma 3.4L SR5 4x4
    That is the one thing I was wrestling with purchasing when I did my timing belt etc. about a month ago...I just couldn't quite bring myself to buy a new one, it was like $5-600 from the factory, but as soon as I saw you post that I was regretting not purchasing it.
    Black97v6MT[QUOTED] likes this.
  4. Aug 20, 2025 at 10:49 AM
    Black97v6MT
    iMA0
    tacoLand USA
    Wait for one of the parts dealershops holiday sale and get over 40% off that ridiculous MSRP :spending:
    Did you notice looseness in yours or why did you feel it needed a new one?
    Mine was making a horrific ticking noise days before the event but I had no clue where that noise was even coming from!
    1997tacomav6 likes this.
  5. Aug 20, 2025 at 2:17 PM
    1997tacomav6
    Denver
    I did notice a wobble in mine when the engine was at idle so that’s why I replaced mine and that would be around 400k on that balancer when I did the new heads
  6. Aug 20, 2025 at 2:34 PM
    rish57
    Nope, I inspected it the best I could when it was off, but I really didn't know what to look for besides maybe that hard rubber seperating from the metal...I would assume one would notice some cracking or something, I did also move it back and forth before taking the crank bolt off and it seemed fine, but next timing belt change I'll probably do it...I'm at 270k currently.
  7. Aug 20, 2025 at 3:12 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Mine hit the fan 'literally lol' before 193k :(
    AND I did have it in the local yota shop for diagnostics a couple of times because that consistent noise was worrisome
    I was told it was the clutch throw out bearing making the chatter so I went with that after making a return during the cold winter when sound might travel better, sounded like right behind the grill but I was assured it was the throw out bearing and that sounds can travel around..which is true lol
    rish57[QUOTED] likes this.
  8. Aug 20, 2025 at 3:34 PM
    rish57
    Just out of curiosity, how would you describe the sound it was making?
  9. Aug 20, 2025 at 3:42 PM
    Black97v6MT
    iMA0
    tacoLand USA
    Right Before it literally hit the fan?
    I took an audio the day before when it was at its worst noise I found out what it was but even got lucky there
    Are you MT or AT?
  10. Aug 20, 2025 at 3:44 PM
    rish57
    AT
